Computers & Internet Logo
Posted on Nov 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a screen for the lapta laptap for a compaq c 700
joecoolvette
Level 3:
  • Compaq Master 5,660 Answers
  • Posted on Nov 22, 2010
joecoolvette
Compaq Master
Level 3:
Answers
5660
Questions
0
Helped
2305099
Points
18015
From a quick search on the internet,
http://www.buy.com/prod/compaq-presario-c300-c500-c700-15-4-lcd-screen-glossy/q/sellerid/23890586/loc/101/211871209.html
http://www.screentekinc.com/Compaq_Presario_C700_Series_C731TU--15.4-inch-laptop-lcd-screen.shtml
Need the Service Manual? (Free)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go down to the line that starts with Compaq Presario 1100, then go across to > C700, and click on it.
This is a PDF file. After you click on C700 you may not see anything happening for up to 30 seconds. The file is downloading in the background.
After you see the first page come up, I suggest you let the file download all the way before looking through it.
(Took 7 seconds for the first page to come up, and an additional 53 seconds for the file to fully download, just now.
I'm using a medium speed DSL connection)
Page 55 - Display assembly
1) Work on a table
2) Observe Anti-Static Precautions.
3) Use a multi-compartment container for the various screws you will remove.
Mark the compartments for the area the screw/s came out of.
Do NOT mix them up!
If no multi-compartment container is available, you can use a clean egg carton. Mark the egg holders.
4) When you remove the LCD screen, look at the back. Write down the manufacturer name, and part number. Match it up to the one you're going to buy. Make SURE it it is the correct size.
(The screen is measured diagonally. From corner to corner)
If the screen is dark, and there is no apparent physical damage to it, do not assume the problem is the LCD screen.
Laptop on use a flashlight to see if you can see faint images.
If so, 90 percent of the time the problem is a bad Inverter.
A small circuit board located at the bottom of the Display assembly, and behind the Bezel.
MUCH cheaper than an LCD screen.
If you need guidance in replacing the LCD screen, or Inverter, and would also like some tips, post in a Comment.
Regards,
joecoolvette
Compaq c 700 raster display
it's looks easy - you need correct(!) drivers
DEAR SIR I AM USING COMPAQ LAPTAP C700 MODEL, HOW TO DOWNLOAD AUDIO DRIVERS
Go to Compaq website put in your sysstem details and down load driver then click run to install
2answers
Sir ihave c795tu laptap in this system only support vista but iam using windows xp.all fuctions are perfectly worked but headphones are connect the output of actual speakers are also coming
Double right click on the speaker icon in the taskbar tray. Then turn the speaker volume all the way down and adjust the headphone volume to the level you would like it. That way you will get sound coming rom the headphones only and not the speakers.
I had a toshiBa laptap i had lines gren en red ...
SEEMS TO BE YOUR SCREEN PIXELS ARE DAMAGED, IF IT IS CHEAP TO REPLACE THEN DO IT...CHANGE THE SCREEN
2answers
Problem with audio driver
check your BIOS if the souncard is enabled.
install the chipset driver first
then install the sound driver.
be sure you are installing drivers for XP not Vista
Audio drivers
your laptop has got high definition audio drivers, i think you are using windows xp, because windows vista drivers are available on hp site, for getting the xp drivers you have to go to hp compaq site, go to support, go to live chat option there they will give you the link for the xp drivers
Top Compaq Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Frank Fernandez
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
