Dell Dimension E310 PC Desktop Logo
Brian Hadden Posted on Jun 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which one? Which one is the ethernet driver?
Anonymous
Level 2:
  • Expert 68 Answers
  • Posted on Oct 31, 2008
Anonymous
Expert
Level 2:
Answers
68
Questions
0
Helped
46918
Points
101
To make sure that you have the correct driver go to support.dell.com,click drivers and downloads and enter your service tag, service tag is the 7 alpha numeric character found on the machine or you can press the f2 when you see the dell logo and find your service tag there, once you have entered your service tag the page will show you the actual drivers for that system.
Gerson War
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 106 Answers
  • Posted on Jun 21, 2008
Gerson War
Expert
Level 2:
Mentor:
Answers
106
Questions
Helped
39993
Points
221
Dimension E310 Desktop, copy and paste this link to a web browser and it will open the Open/Save prompt for the driver http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=136142
Or you can go back to the support page and look for the driver under the NETWORK menu Which one? - hiernest.gif (R) PRO/100 VE Network Connection
Let me know if it does the trick :)
Gerson
3helpful
2answers
Driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
3helpful
Need ethernet driver for emachine t3624 where can i get it from
- I wen to e-machines website and found out that there are no available Ethernet driver
- Since the chipset drivers are from intel more than likely that the ethernet drivers are also from Intel
- For you to be specific on what Ethernet driver it is you can check on
1. device manager -> left click on the plus/triangle sign next to other devices
2. right click on ethernet -> choose properties
3. from the properties window --> click on the details tab
4. there should be a long alpha numeric number starts with PCI......
5. google that up for you to find out what specific ethernet driver it is
- If the ethernet driver is from Intel here is the link:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22PL2KXPM.EXE%22
-- Cheers Don' t forget to say thanks
2answers
I loaded xp pro but my ethernet port is not active. Do I need to load ethernet drivers?
That means that the operating system doesn't have a database for your Ethernet device. You have to have the driver that came together with your PC and you should find the driver for your Ethernet device using that.
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
4helpful
How i istall ethernet driver from internet
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
1helpful
Ethernet controller has a yellow ! makr after it
reinstall the ethernet adapter driver from the dell drivers and utilities and extract the necessary ethernet driver under network driver
2helpful
2answers
1helpful
4answers
Please, ethernet controller issues.
You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD.
If you don't have driver CD with you then You can download ethernet driver by Clicking here.
Thanks
Ethernet drivers
Windows XP Driver
Windows Vista Driver
These updates should sort out ethernet problems.
If these don't work or you have Wireless LAN, here is the Wireless LAN driver.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
