kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
Posted on Nov 20, 2010
Where can I get a replacement trigger switch? The one in the drill is in a locked position and cannot be moved. I too the drill apart and got it to move now there is no responce This is a 19.2 volt model
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
4357
Points
21
Call the service # and they will send you a new drill, mine had a burn mark right through the switch and with the model # they replaced it mine was a21.6 they are having troubles with the triggers i pulled mine a part and when i put a battery in it it would run continuous , the number should be on the drill1-800 590-3723
2 Related Answers
Robert Koch
  • 165 Answers
  • Posted on Feb 27, 2010
SOURCE: Craftsman 14.4 drill chuck stuck in open position
Look inside for centered screw and remove.
Anonymous
  • 576 Answers
  • Posted on Mar 07, 2010
SOURCE: I have an 18 volt hammer drill combo drill. I
Do the same in reverse, if possible. Also, you could use two channel locks as most of those chucks have two rings, the narrow one towards the drill itself being attached to the motor. However, make sure the screw inside the chuck is tight first -- I've seen those back out and block chucks open.
Top kawasaki Drills Experts
john h
Steve Pack
Steve Pack
Anonymous
Level 1 Expert
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
