Hey irfa,
If you've lost sound on your computer, there are a couple of suggestions that I would make before seeking any kind of repair.
First, you may want to check your computer's audio control panel to make sure that the speakers haven't been accidentally muted. In most versions of Windows you can check this by clicking on the "Start" menu, choosing "Settings" then "Control Panel." Once in the control panel, you'll want to double-click on the "Sounds and Audio Devices" icon. Please note that you may have to choose the "Classic View" option in certain versions of Windows XP in order to see this icon. Once the audio device properties menu has been opened, on the first tab (labeled "Volume") there should be a sliding bar that allows you to set your speaker's volume level in addition to a checkable "Mute" button just below. Make sure that this is not selected, and then press the "OK" button.
Second, you may want to make sure that your have the most up-to-date drivers for your sound card. Many drivers can be obtained by performing a Microsoft Update or by visiting the computer manufacturer's website. In this case, you should be able to find drivers for your HP D530 by visiting the website I've provided a link to below:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=316722&prodSeriesId=316720&prodTypeId=12454&taskId=135&swLang=13
You'll need to choose your operating system from the list provided, and simply scroll down on the page to the "Driver - Audio" download section for the latest HP-recommended drivers.
Next, you may want to try using a different set of speakers if you have one available. Should other speakers function normally, your original speakers may simply have shorted out. If other speakers do not function either though, you may potentially be looking at a failure within your computer's sound card instead.
If you’re still unsure how to proceed, remember that you may always contact HP directly or a local computer repair technician (like a Geek Squad® agent at your local Best Buy™ store) for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
if u want drivers for Compaq D530sff please use below link ...select correct OS...
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=316715&taskId=135&prodTypeId=12454&prodSeriesId=316713&lang=en&cc=us&y=7&x=9
If this link is useful for u please Rate me...........
Hi this is shani.My problem is that i dont know what are my sound & display makes and their drivers.i just need to know the makes and drivers of my system.please help me.Im using the HP d530 SFF(DQ392S).Icopied this information from system information (DxDiag). Thank U.
