Brinkmann 810-2300-B Grill Logo
Posted on Jun 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Low flame I have a Brinkmann gas grill. I'm not sure what model it is but I got it from Wal-mart about 3 years ago. It has a low flame. I thought it might just be low gas but I just refilled the tank and it still has the same problem. I have a decent flame if I just use the center burner but if I turn on the other burners they all have a very low flame. Any suggestions?
  • 1 more comment
  • Anonymous Jun 17, 2008
    I have a Brinkmann Grill and 2 of the burners are working fine but the third one was shooting the flame out the front of the burner but not all the way around.
  • Anonymous Nov 01, 2008
    Normal flame in the center burnner but if i tun on the other burnners the flame reduces with low heat. Unable to cook.
  • Anonymous Mar 17, 2014
    sideburner works but main grill has no adjustment on burners - turn knob on , get a whoosh and then hardly any gas flow
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1631
Points
Solution #1 is correct. If your regulator is / was good, then you would most likely have a leak in a line or fitting - and the regulator has properly restricted or stopped gas flow as it's designed to do for obvious safety.
However a very common leak is the main plastic tank coupling which renders the whole regulator and hose assembly useless.
Quick fix, go to Wal-Mart and buy a $20 replacement regulator which comes pre-fitted with hoses and couplings. Get the dual or single hose depending on whether you have a side-burner or not.
Voila! Your good to go a few more years.
Anonymous
Level 2:
Champion:
  • Expert 254 Answers
  • Posted on Jun 22, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
254
Questions
Helped
143615
Points
402
This is a problem with the regulator. It is not allowing enough pressure to maintain the burners when all are lit on hi. You can get these regulators at most major retailers or directly from th emanufacturer.
Hope this helps you out.
Top Brinkmann Grilling Experts
Paul Carew
Dennis
john h
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
