SOURCE: Sharp AR 5316
It worked thanks alot.
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
SOURCE: U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
SOURCE: Sharp AR-163 Copier
replaced your toner cartridge with a new one, if you install a new one and it didn't work and still F2 flashes, the cartridge that you buy is not suitable for your country, always ask for a genuine toner, do not use compatible toners for your copier.
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
