SOURCE: Shortening the Length of a Metal Wrist Band
Take your watch to a jeweler and they should do it for you free of charge.
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
SOURCE: Shock Absorber replacement 2002 Explorer Sport Trac
These are just regular shocks and not struts so they should come out with just common tools. You may need to soak the fasteners in penetrating oil for a while or, use heat tget the fasteners to break loose from the corrosion.
SOURCE: How Do I Remove & Replace Worn Inner Tie Rod Ends
Cut band clamp. use tie wrap. Special tool to remove inner tie rod. Autozone or others have them to rent. Must align after replacement
