Computers & Internet Logo
Posted on Oct 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a problem the problem is error 429 - Computers & Internet
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Oct 30, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1573516
Points
28391
The 429 error, "ActiveX can't create object" is a common Visual Basic runtime code error. Insert the phrase into a search engine and you'll see what I mean.
According to Microsoft, unlike some errors in Visual Basic, there is no one cause to an error 429. It happens because of an error in the application or system configuration, or a missing or damaged component.
There's some background on this at
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vbenlr98/html/vamsgCantCreateObject.asp
If your error was within Office, reinstall Office as it has probably lost a file somewhere and make sure your Active X is up to date. Running a goog defrag programme may also help.
Hope this fixes your problem.
Yamaha HTR 5950 shutting off, tmp 429 error
test it in cool room not packed deep in some cabinet.
see if it is overheating (tmp)
also tested it in free space (no cab) and no speaker
the manual makes no mention of tmp or 429 errors so,, not good that.
things like this love to over heat, I make sure mine AVR has fresh clean cool air all the time with my cabinet vents and I raised mine on 1 inch boards 1"x18" under the feet front to rear, and this lets lots of fresh air go the vents
make sure all AVR casing vent are dust free>?
found your service manal
and TMP means this quoted
"The protection function worked due to the
temperature limit being exceeded. Causes
could be poor ventilation or a defect related
to the thermal sensor. If the power is turned
on with the abnormality unsolved, the pro-
tection function works in about 1 second to
turn off the power" (and saves its own bacon, a super good that)
this error is stored in the logs, so that is only history.
here it is (the real; deal and free) PDF
https://elektrotanya.com/yamaha_rx-v559_dsp-ax559_htr-5950_sm.pdf/download.html#dl
I have a 429 ford motor i think it has. Non ajusting lifters but there is some lifter noise
Your 429 has solid lifters and they are adjustable. It's Tricky. Way to much to explain here. go on line and type in Adjust 429 solid lifter. There are several sites that have good instructions
2answers
429 error active x
It looks like the solution is to download this file:http://www.microsoft.com/download/en/details.aspx?id=8247
I found this information on this website:http://www.ehow.com/how_6018818_fix-active-error-429.html
The most recent version of this script is 5.7, not 5.6, but it should fix the problem. Also, make sure you have the most recent updates through Windows Update and Service Pack 3. Install the script first, however.
I have directx 10 but still can not fix the Runtime Error 429. What should i do?
Error 429 issue is caused by corrupted Windows registry.
The first tips to fix runtime error 429 is to run security scan on your computer.
http://www.filehippo.com/download_spybot_search_destroy/
Repair your system's registry with http://download.cnet.com/RegScrubXP/3000-2094_4-10820427.html
Also you can try to go to the Microsoft Windows Script update page to fix runtime error 429. http://www.microsoft.com/downloads/en/details.aspx?FamilyID=47809025-D896-482E-A0D6-524E7E844D81
If possible download XP SP3 http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
Hope my solution will help you...
Have a Nice Day
8helpful
2answers
Runtime '429' error
It sounds like your product is not compatible to Vista....you may need to email the creators of this product and ask them for the update if they have made one YET.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
