Televison & Video Logo
Posted on Oct 27, 2010
Sky remote code needed for gtvl37w17hdf goodmans flat screen 37 inch tv to make volume work on sky remote please
5 Related Answers
Anonymous
  • Posted on Jan 08, 2009
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Anonymous
  • Posted on Feb 18, 2009
SOURCE: trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Anonymous
  • 27 Answers
  • Posted on Apr 04, 2009
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Anonymous
  • 27 Answers
  • Posted on Apr 08, 2009
SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Anonymous
  • Posted on Jul 10, 2009
SOURCE: progamming code for DYNEX t.v. w/ brighthouse cable remote
Do what I did...
Turn on TV
Press TV on the remote(will blink once)
Press and hold setup until tv button blinks twice
Hit 991 tv key will blink twice
Aim remote at tv press power button once
Press the Chan + key over and over until tv shuts off.
Same instructions as the manual
Top Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
