Panasonic DMR-ES30VS DVD Recorder/VCR Logo
Posted on Oct 23, 2010
What is error code ug1 (or u61?) - Panasonic DMR-ES30VS DVD Recorder/VCR
3 Related Answers
Anonymous
  • Posted on Jan 26, 2008
SOURCE: u61 error code
UMM the DVD top lid uses FOUR screws. The entire DVD drive is bolted to the chassis with 3 screws.
Anonymous
  • 5 Answers
  • Posted on Sep 21, 2008
SOURCE: Error code U61 on a
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Anonymous
  • 55 Answers
  • Posted on Apr 22, 2009
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
4helpful
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
2helpful
U61 ERROR ON DISPLAY
U-61 is a hardware error code. Usually means main board failure, however have found that a bad changer can also trigger that code since it connects directly to the main board.
2helpful
U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
5helpful
ERROR CODE U61 panasonic dmr-ez45v
I HAVE A DMR-EZ45V WITH PROBLEM U61 IS THERE ANYWAY OUT OF IT
5helpful
From User guide:
DMR-EZ25EB; Error code U61 cannot be recovered
take it to a tech to check about the system control chip... the contril chip would have gone bad... and they will replace u with a new chip..
thank u rate me!!
Error code U61 on a panasonic DMR-ES35v When I turn it on it says "Please Wait" end the code U61 occurs after som while.
2helpful
2answers
Error code u61 will not clear, unable to reset the DMR-EZ45VEBS
Hi, there was no solution to my problem with the error code U61, having talked to a Panasonic repair center it would cost £180.00 to fix this unit as the board and DVD recorder have to be replaced as one unit. It would cost me around £160.00 to buy a new one so there was no point in having it repaired.
1helpful
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
2helpful
3answers
U61 error code
Top Panasonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
