Computers & Internet Logo
Posted on Oct 22, 2010
How do i block a websites using at wa1104g allied telesyn router
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Aug 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
14081
Points
27
For blocking certain websites, you can edit the Hosts File, and it goes this way 1. Open MyComputer 2. Browse C: (or your Operating system drive) 3. Browse Windows ->System32->drivers->etc So the Location will be C:\WINDOWS\system32\drivers\etc In the etc folder look for the file hosts 4. Open this file hosts with notepad. 5. At the bottom of the file, add the line as shown below: 127.0.0.1 www.***.com 127.0.0.1 www.***.com ... 7. Save the file. 8. reboot your computer. Note: In this way add any number of sites you want, however you will need to prefix it with "127.0.0.1". And this way is easily got around http://www.aobo-****-filter.com/
Anonymous
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Aug 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
23197
Points
25
You can block it by modifying the hosts file or use some smart filtering apps like website blocker, more info: http://www.monitoring-softwares.com/
Hope it helps.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Oct 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
646
Points
10
Internet Explorer using Google Chrome
1. Load your Internet explorer
2. Click Tools
3. Click Internet Options
4. Click the Privacy tab
5. Under the Privacy window, Click Sites
6. Type in the site address that you want to Block and Click OK. Remember this technique only blocks on one site at a time. Parental control software will allow you to block multiple sites and categories.
Block a Website using Google Chrome
1. Open your Chrome Web Browser
2. Click the wrench symbol in he upper right corner.
3. Choose Tools
4. Click Under the Hood tab.
5. Choose Change Proxy Settings.
6. Click Security, click Restricted Sites
7. Double click Sites and add the site you want block
Can't find user and password
Reset your router and login with default factory settings.....Find the default username and password from user manual....
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com
1helpful
Ip default at-wa1104g
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
How to Allied Telesyn Switch password reset?
The Allied Telesis website says this:
How do I recover a lost user's password on Layer 3 Switch or Router? ...
If a user forgets their password, the password can be reset from an account with MANAGER privilege, using the command:
SET USER=login-name PASSWORD=password
Another website has this to say:
device has a reset button.. you can push that via pen, check the devices handbook you will see that mini button..
push that button for a ten second... and release.. your settings will reset.. default username : manager password: friend
1helpful
Password router
You can not get the old user name and old password.... you have to reset the router to factory default settings but then you have to make all the settings from scrach.
Allied telesyn at wa1104g router lags
is it possible that someone else is using your bandwidth? try changing your security settings.
Cannot connect the wireless router
You will need to know thr router ip adress enter it in the internet browser and after that it may ask you for a user name and password. I hope this solves your proble.
1helpful
Upgrade firmware
I believe I may have found what ya need here --> http://network.free-driver-download.com/allied%20telesyn.html
Disconnected
in my experience invariably it is the hardware at issue.. occasionally it is the driver(s) So uninstall the drivers, Obtain the latest.. install, configure ... Change any cables also, if all of that doesn't "fix it" then we are back to our original diagnosis of the "Hardware" problem.
Port Forwarding for Allied Telesyn AR725
If you refer to this link, it should explain how to do it for you, best of luck http://alliedtelesis.custhelp.com/cgi-bin/alliedtelesis.cfg/php/enduser/std_alp.php?p_sid=psCY4LAi&p_lva=&p_li=&p_page=1&p_prod_lvl1=5&p_prod_lvl2=63&p_search_text=port&p_new_search=1&p_search_type=3&p_sort_by=dflt
go to this link for instructions, best of luck http://alliedtelesis.custhelp.com/cgi-bin/alliedtelesis.cfg/php/enduser/std_alp.php?p_sid=psCY4LAi&p_lva=&p_li=&p_page=1&p_prod_lvl1=5&p_prod_lvl2=63&p_search_text=port&p_new_search=1&p_search_type=3&p_sort_by=dflt
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
