Dirt Devil Easy Lite Quick Vacuum Logo
Posted on Oct 21, 2010
How do you empty the dirt out of it - Dirt Devil Easy Lite Quick Vacuum
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Oct 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
955
Points
9
The plastic dirt holder should have a lever that opens the canister.Should come right out with a slight pull.empty contents into the trash.
How do you empty the turbo accu vac? I can take the filter out and clean it but can't open the chamber where the bits are collected
  1. Make sure to turn off your machine.
  2. Press the empty button. Then pull the handle to lift the dirt container away from the vacuum.
  3. Hold the dirt container over a trash bin and press the release button to dump the debris.
  4. Then snap the bottom back on.
  5. Place the dirt tank back onto the machine.
How and were do you empty the dirt?
Check it. When the bag is full, it's time to empty.
How do you empty it?
http://www.homedepot.com/catalog/pdfimages/e1/e1548aa7-3a91-42bc-b2c0-1b405ef54686.pdf
This owners manual shows you how to empty. If you dont have access to Internet:
1. Depress the dirt cup release button and pull nozzle away from unit.
2. Hold nozzle over a wastebasket, Grasp filter and gently pull out.
3. Shake excess dirt and debris out of dirt cup. Brush the dust and dirt off the filter or shake inside the wastebasket. IMPORTANT do not wash filter.
4. Gently push the filter back into the dirt cup.
5. To reattach dirt cup: Align bottom first and rotate nozzle up until it snaps into place.
Good luck.
Why vaccum not emptying
Hi! If no dirt is entering into the dirt cup it could be that you have a clog in your hose. Detach the hose from both ends and use a broom stick or something similar to carefully loosen and remove any clogs in the hose. Hope this helps! If not you can always reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil. Thanks!
1helpful
I have a dirt devil easy lite... how do I empty the top canister? I know how to empty the bottom half.
The upper half is where the filter is.
Here is the manual:
http://dirtdevil.com/file/172/
Page 7 shows after emptying the lower container, "Twist and lift to remove dirt container lid."
Is blowing dust out as I vacuum
In your manual:
Visible dirt escaping from cleaner
Possible Causes: Remedies:
1) Dirt Container full 1) Empty Dirt Container
2) Filters missing or installed incorrectly 2) Check Upper Tank, Pre-Motor and Post-Motor
Filters for correct installation
3) Dirt Container installed incorrectly 3) Pull out and re-insert Dirt Container correctly
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
2helpful
How do I take it apart to empty the cone?
the cone where the dirt goes in will twist off about 1/4 turn and then lift out the filter to empty
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
6helpful
How do i open my dirt devil kone to empty it?
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
5helpful
I have acquired an old Regina Electrik Broom
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Top Dirt Devil Vacuums Experts
Sudeep Chatterjee
Sudeep Chatterjee
Paul Bade
jdthefixer
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
