SOURCE: I need a kitchenaid professional 600 service manual
Hi. Kitchenaid does not provide Service Manuals but you can goto the www.kitchenaid.com website, enter your model # and search for the Parts List for your mixer. Download these files, these will help you to disassemble and reassemble your mixer. The part numbers will help when ordering.
You don't say what broke on your mixer. If you'd like further guidance, post a comment or clarification and I can help walk you through it.
If this solution has assisted you, please rate it. Good luck! ricardok45
SOURCE: Paddle Scraping - KitchenAid Professional 600
There is an adjustment screw and a system for setting it. You can find a video of it here (or just a ton of people who know all about these mixers). I just found it while trying to troubleshoot the same problem for my wifes mixer.
http://forum.kitchenaid.com/forums/forum.asp?FORUM_ID=196
SOURCE: wont turn on
Power supply or brushes,
estimated cost $39-$49.00 with warranty
ship USPS it's very inexpensive
SOURCE: Kitchenaid pro 600 KP26M1X looking for a printed circuit
Hi VIC. The PC board you’re looking to replace is called the “Control Assembly” inside your mixer’s head, and yes you can order and replace it yourself. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.)
For a series -4 mixer, turn to pgs. 2 & 3, titled Case, Gearing And Planetary Unit that shows an exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 8, Control Assembly. This is where I suspect your problem lies. (For a series -5 mixer, turn to Pgs 4 & 5, and locate Illus. No. 18, which is the Control Assembly). You just decide if you need to order a Black Knob or Grey Knob Control Assembly
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. I don’t know if these vendors mail internationally, but you should be able to check their websites and find out.
Once apart you can check your mixer for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Testimonial: "Thank you so much hslincoln! The only thing is that I don't know how to know which Knob to order (the black or grey one...) Vic"
SOURCE: I have a KitchenAid 600 professional stand mixer.
You can knead longer than that, but you run the risk of over heating the mixer because at that point the dough is very firm. Your best bet is to knead it by hand.
