GE DRSR483ED Electric Dryer Logo
Posted on Oct 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer Squeaks - GE DRSR483ED Electric Dryer
Curtis Sewell
Level 3:
  • GE Master 7,482 Answers
  • Posted on Oct 16, 2010
Curtis Sewell
GE Master
Level 3:
Answers
7482
Questions
Helped
1976353
Points
24948
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Stacked one piece washer dryer.Dryer squeaks
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Ge driver 10 years old dryer squeaks and if i manually spin drum squeaks what should i do
heatman101
1helpful
My Frigidaire dryer squeaks loudly.
heatman101
My dryer squeaks when running a load. How do I fix it?
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Dryer squeaks while running. What could the
brand helps but sqeeking is normally a idler pully,,,glide,,or drum wheel/support www.myabcspace.com/washerwizzards
The dryer squeaks when first started, then is
the belt that connects the motor to the drum needs replacing
The seal around the drum is dry or tacky and or the belt tensioner roller bearing needs to be replaced
Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
DRYER SQUEAKS REALLY BAD UNTIL WARMED UP
I took apart the dryer, cleaned and greased the bearing that had no grease left at all(therefore I assumed no easy movement) and it worked.
1helpful
Squeaks
Hi! swtkns47
Make sure the dryer is level and sitting on a solid surface. You need to check the blower, and all the rollers. There is a static wiper on some machines to ground the drum. This may be worn down and rubbing incorrectly.
InMrFixIt
Top GE Dryers Experts
vince
Axel Gringmuth
Are you a GE Dryer Expert? Answer questions, earn points and help others
