Washing Machines Logo
Posted on Oct 12, 2010
E14 error code on hoover optima washing machine
5 Related Answers
A
Anonymous
  • Posted on May 07, 2008
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Anonymous
  • 193 Answers
  • Posted on Sep 28, 2009
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Anonymous
  • 4323 Answers
  • Posted on Aug 01, 2010
SOURCE: hoover oph 714d optima 7kg
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
Anonymous
  • 15935 Answers
  • Posted on Sep 07, 2010
SOURCE: whirlpool washing machine displays error code e14
To prevent the washer from operating while the detergent drawer is open your machine has what is called a "reed switch". The reed switch is controlled by this magnet, so that when the drawer is closed the magnet causes the reed switch to close and this tells the control board to go ahead and run the machine.
Your error message is telling you the reed switch it not working, so they want you to check the magnet to make sure it is still in place and is working.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • Posted on Jan 28, 2011
SOURCE: hoover optima oph714ds error code
hoover optima oph 7d14 working ok but at end of wash cycle error e14 comes up what does this mean
Top Washing Machines Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
