New colorink is new black ink is old but printer doesn't print right when test page alinement
I've had this problem many times and the only thing that works is to completely shut down your computer, and then SHUT OFF THE POWER TO THE COMPUTER AND PRINTER for a minute or two, then restart. when you restart, the paper should feed thru the computer by itself and then you are all set.
Sounds like a piece of paper is stuck inside the machine. Open all access doors and check. Remove the printer cartridge and reinsert. Make sure the print job has been purged from the queue.
Paper does't feed. All printing in in top two inches.
I checked for pieces of paper, could not find any. Several times I turned the printer upside down and gently shook, nothing!
After just giving up for several weeks I decided to try one more time before trashing it. I turned it upside down and tipped it from sided to side and heard a rattle. After several side to side "shakes" a white plastic gear broken fell out. So now I know it has a plastic gear wheel broken. Now the question is "How do I replace it"
