Grohe Grohtherm Thermostatic Rough-In Valve 3/4'' Valve - 34125000 Logo
Posted on Oct 08, 2010
I have a message on the control panel of my Grohe wireless shower saying CLEANUP. What's that mean?
2 Related Answers
Anonymous
  • 61 Answers
  • Posted on Jun 28, 2010
SOURCE: Install trim and adjust the thermostat on a Grohe shower faucet
the temperature adjustment dial cna be rotated when you loosen it, take a thermometer , turn the water on and set the temperature dial to the right temp, then tighten the screw holding it and you're all set
Anonymous
  • Posted on Sep 24, 2010
SOURCE: what is service code 1 for a grohe wireless
I had the same Service Code 01. The solution is simple. Switch off the power for the shower for a minute or so usually located outside of the bathroom. Switch it back on and you should hear the unit (if it's close by) resetting itself. Switch on the shower and it will tell you to wait, then with a bit of luck it should wizz into action.
I've just installed a grohe mixer shower/bath
Did you account for wall thickness?
Limit is displayed on my grohe digital shower what does it mean
Limit message is when the output water set temperature can not be reached, this is normally when the incoming hot water to the shower unit is not sufficiently hot. Service code 20 is something else inside the unit that is faulty, it could be a number of faults. Try reset Power down unit and re-start, it will either say Wait or Priming, after that it should restart, hopefully it will work. If not, you could have a internal fault with: The mixer valve/motor, the flow control valve or motor, the flow sensor. If you have hot water from other taps, then the mixer valve/motor is the most likely fault. If you only have cold water only from the shower head with limit message it could be the Hot solenoid controlled valve is faulty. Good luck as there are no spares available!
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
4helpful
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
16helpful
2answers
What is service code 1 for a grohe wireless shower
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Top Grohe Water Heaters Experts
    Paul Carew
    ADMIN Andrew
    ADMIN Andrew
    vince
    Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
