Epson Stylus CX6600 All-In-One InkJet Printer Logo
Posted on Oct 03, 2010
Black won't print for my epson SX515W - Epson Stylus CX6600 All-In-One InkJet Printer
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 02, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3557
Points
6
I have solved this problem on my sx515w. I hadn't used the printer for a while and when I did after about 3 months the black wouldn't print. Even after trying several different new cartridges, driver reinstals, updates, automatic head cleaning operations..... It turned out that the printer head had ink dried onto it due to lack of use.
What you need to do is to drop a few drops of nail polish remover (yes as in Acetone solution) on to the foam cleaning dock, located to the far right of the printer rail. When the printer is resting, the ink jet module covers the dock. TO expose the dock, set the printer to the 'clean head' operation and the ink jet module will go to the far left, when this happens pull the power cord out so it stays out of the way (don't worry the printer will reset fine afterwards).So now the module is out of the way drop in some cleaing fluid on to the sponge dock. Then you are ready to run the automatic clean head operation at least 20 times. Do a test print each time until full print quality is resumed.
Oh and it is worth cleaning the sponge dock with tissue as it gets heavily soiled with ink (using the 'clean head' - turn off half way operation just described above). Remeber to replenish the nail polish remover. This should sort it.
Yackshimash.
Cheers
  • iluvmarmite Jan 19, 2011
    didn't work for me!! :-( .. have now spent a fortune on 4 packs of multipack inks due to the amount of ink wasted during head cleaning and it made no difference whatsoever! :-(
  • Shop Pakistan
    Shop Pakistan Dec 31, 2018
    https://www.shoppakistan.com.pk/61/Healt...
5 Related Answers
Anonymous
  • 163 Answers
  • Posted on Apr 03, 2009
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Anonymous
  • 133 Answers
  • Posted on Jan 01, 2010
SOURCE: Cannot print documents wirelessley from SX515W
in vista as with windows 7 you must tell the computer to connect to your printer in network preferences. It wont work untill it is told to connect!
Anonymous
  • Posted on Jul 10, 2010
SOURCE: my epson stylus sx515w has stop printing black
I have exactly the same problem with the black ink. Anyone have any solution
Anonymous
  • 540 Answers
  • Posted on Jul 25, 2010
SOURCE: My epson sx515w wont print black
Please clean the print head to resolve the issue.Open the link below then click on any of the link to get the instructions as per your OS name like Windows or MAC etc....
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX515W/Drivers-Support?target=article&extn=.html&articleId=1085
Anonymous
  • Posted on Aug 04, 2010
SOURCE: My epson sx515w is not printing from the black cartridge
Had the same problem. I put some white spirit in a syringe and placed the syringe nozzle over the ink nozzel and squerted it in to unblock the system. Inserted a new cartridge. It now works again for me, so far so good ??
SX515W black cartridge won't print
thake the catridge head out and put it in worm water for 30min dry it and test it if it is not working. it need to be replaced.
1helpful
Epson SX515W black ink jet blocked. Anyway to clear it myself?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
2helpful
My epson stylus sx515w has stop printing black
3helpful
5answers
3helpful
2answers
I have a Mac Book. Recently installed an all-in-one epson sx515w. Whenever I try to print, a popup window says ''remaining ink level. Then, I get the message ''printer currently off line'' Can anyone...
First of all, check to make sure your printer's USB cable is securely connected in your Macbook's USB port.
Next, make sure your Epson SX515W has the latest drivers installed for your current version of Mac OS X
Link:
Mac OS X Drivers for Epson SX515W
If you already have the updated printer drivers for your Epson SX515W already installed,
go into System Preferences> Print & Fax and see if the printer is displayed in the Printer window. If it is, click the "-" Minus button and remove your current printer.
* Click the "+" Plus button and re-add that printer.
Once you do, make to set it as the default printer.
- Now attempt to print a test page from any document you have.
See if this does the trick. If if does not, just let me know.
Regards.
-Mactechtrainer
Epson sx515w wont fully install on my windows 7 laptop wirelessly
Look in http://social.answers.microsoft.com/Forums/en-US/w7hardware/thread/64f2f003-7c0b-4809-b376-e610b370fceb
Normal 0 21 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} "Problem getting wireless Epson SX515W connected to laptop running Windows 7"
In my case I had the SX515W configured via USB with other computer with Win XP, and later working by WiFi.
With may new laptop with Win 7, I have the error with the NetSetup installation CD.
First I checked that it was possible to print via USB with the laptop, and after I added by wifi using the "add new printer wizard" as explain Quagmire69 in the link attached.
Good luck
3helpful
Top Epson Office Equipment & Supplies Experts
Rommel Balcita
Grand Canyon Tech
Grand Canyon Tech
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
