Olympus VN-3100PC Digital Voice Recorder Logo
Posted on May 26, 2008
Error message My Olympus VN-3100 voice recorder has suddenly stopped working! When I switch it on it flashes CHK for a couple of minutes then says ERR. Help!
  • 1 more comment
  • Anonymous Oct 11, 2008
  • marychlopek Oct 17, 2008
    Have not had the device more than a week or two. Sadly it has about 40 notes I REALLY need to get off. Have you tried connecting to the PC?
  • Dallen Tubbs
    Dallen Tubbs May 09, 2018
    Does the recorder need to be hooked up to a pc for this function to work?
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Dec 26, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
9541
Points
47
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again. I hope this solution works for your model!
  • Scott Mahrenballz
    Scott Mahrenballz Oct 16, 2018
    Thank you for this.. I can verify this method does work for the vn-3100pc but just beware it formats the drive so you'll lose anything you had saved. I found this little recorder while cleaning out an estate in a box that was headed for trash, so I guess they couldn't figure it out and thought it was broken.. but with just a couple of fresh batteries and doing this it works like new again! Thanks again!
  • David Saucier
    David Saucier Sep 07, 2022
    Mine done like you said it would do but then it went right back to ERR have you anybody seen a solution to that
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: My Olympus VN-3100 voice recorder has suddenly
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory (ERR means memory error). Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
Testimonial: "This solution really worked, thanks man!! Merry Christmas!!!"
Top Olympus Audio Players & Recorders Experts
Rommel Balcita
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
