Sharper Image Ionic Breeze 3.0 Air Purifier Logo
Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The unit won't just start and I suspect some kind of electrical problem (transistor or fuse damage)
Ginko
Level 3:
  • Master 19,396 Answers
  • Posted on Sep 24, 2010
Ginko
Master
Level 3:
Answers
19396
Questions
25
Helped
8264276
Points
55462
Hi.
To get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read the below, in that case do not get the parts.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
1helpful
Find out the electronic circuit voltage
I am an electrical engineer and I do not fully understand your question. If the unit is designed to operate on 50/60 Hz, it cannot be damaged by operating it at either of those line frequencies. Mnay products today will operate at either line frequency.However, if you used an adjustable voltage power transformer (a.k.a. "Variac"), you may have "under-voltaged" or "over-voltaged" the device. If there is a circuit breaker, try resetting it. Otherwise, there may be a circuit board-mounted fuse internally that is now electrically "open." That can be tested with an Ohmmeter for continuity. (Finding a replacement may prove difficult.)
Operating a line-powered device above or below its input limitations can permanently damage internal power supply functions and, perhaps, other circuitry as well.
Solid state components can fail "open" or "shorted." If they fail "open" they will not draw appreciable current to "burn" them in any obvious way.
5answers
Won't start
Check the fuse inside the unit, it is located where power cables hook up.
4answers
Ionic breeze gp
cheak main power unit see if u can get one from radio shack start there do u leave it on 24 7 fan puts on a heavey load on power trasformers blows them easy
Honey well air purifier 17007 fuse blew. how to repair
The fuse is located inside the control panel. It is soldered to the circuit board, not mounted in a typical fuse holder. You will need a Philips screwdriver to disassemble the unit. You will need a soldering iron & solder to remove the fuse and replace it. You may want to a multi-meter to check the fuse. If the unit just stopped working, it could be a number of other issues than the fuse. The starter capacitor for the motor could be dead or some other issue. You must take precautions against electrical shock. You may need a technician to safely perform some repairs.
My unit has been in storage and I have just now cleaned it and put it back together, but it won't come one...how do I know if the fuse is needing replacement.
You power down, take the fuse out, and put the leads of a DVM across it (or have your local prefilter supply place use their DVM.) If the thing blew and therefore reads OL (open line, as opposed to a closed circuit) then you need a new good one. You can't always see metal deposits and a break in the fuse wire.
1helpful
I "won" a Rainmate from
No, not that I'm aware of. But, the problem itself, may be in the electrical receptacle. A loose wire, a bad connection or interior damage could all cause the circuit breaker to trip. Or it may simply be the case, of line that air purifier is plugged into, is simply overloaded, because of other electrical appliances are on the same circuit of tripped the circuit breaker. Most air purifiers have their on circuit breaker or fuse built-in to the unit. And that, will usually trip before the circuit breaker in the breaker panel of your home.
Here's how you test that theory: Plug the unit into another outlet, that is on an entirely different circuit than the original one and turn it ON. If this trips a different circuit breaker, then you know it's an internal problem with the unit. If it doesn't trip the circuit breaker, the problem is with the original receptacle or the line that feeds that receptacle and it's circuit breaker.
Hope this helped you to troubleshoot and solve the problem.
Power won't come on switch does'nt lite up fan does'nt work
First, are you sure that outlet that the unit is plugged into really works? The other situation would be a blown fuse on the back of the unit. Also, make sure that the filter on the back of the unit is seated properly and making contact with the safety switch. Check all three things. It could be any of them.
I lost neutral on the electrical service and my cleaner no longer works, i changed the fuse that had blown, but when i turned the filter on it simply blew the new fuse
Blowing a new fuse would indicate that there is some component of the machine which was damaged. The fuse is a safety device which keeps electricity from flowing through defective wiring.
You can visually inspect the machine to see if there are any wires, connections, or components that appear to be damaged, burned, loose, or broken. The plates need to be perfect, without cracks, burned spots, loose mucilage, broken screens, etc. The contact fingers should be screwed firmly in place, and they should press firmly against the screen part of the plate.
If you can detect and then repair any of the above defects, and if the machine still blows the fuse, you can assume that the problem is deeper in the machine and it needs professional help! Unfortunately, Vollara (formerly EcoQuest) no longer makes or repairs the Flair. You can contact Vollara customer service 800-989-2299 to locate a dealer in your area; they may have another machine or know where you could get one. They may also know of someone who could repair it for you.
2helpful
2answers
I have an Alpine XL - 15 and the ozones only distribute when it is on the highest level. I did purchase new plates and it has made no difference to the operation of my unit. I cleaned the whole unit with...
Hi pierce_marle,
Unless you have a lot more electronics background than I suspect, you probably aren't going to want to get too deep into the electronics components, and because I don't know your personal level of skill with electrical repairs, I'm not recommending that you do so.
It sounds like you've done all the easy stuff. If you have a multi-meter, you could start checking the wiring going to the plates for continuity (checking for broken/damaged wiring, evidence of short-circuits such as blackened spots, etc.)
Beyond that, you might want to see if you can get a similar (same model and plate/motor configuration) on eBay to use for cannibalization/spare parts - - probably the cheapest way to swap-out a chassis of electronics and wiring that I'm aware of.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Top Sharper Image Air Purifiers Experts
john h
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
