Televison & Video Logo
Posted on Sep 23, 2010
Code number for an electroview tv modle number ev32
3 Related Answers
RixsFixes
Radio Code Pro
  • 2200 Answers
  • Posted on Nov 25, 2010
SOURCE: My remote was droped and
Your best bet with this new universal remote is to use the automatic search function. This will scan all remote codes in its library to find one that works with your TV. As you have not provided details of the remote manufacturer and model number, you will need to check the universal remotes manual to find out exactly how to put it into automatic search mode. Essentially your TV needs to be in standby mode whilst the remote scans through its library. As soon as the TV resumes from standby you have found your code.
Be aware that there is a variation in each universal remote and its capabilities in terms of the codes that are stored in that particular models library. All universal remotes are not the same in this respect and the multifunction capability is entirely dependant on the library codes that are stored in that particular remote so if the auto search function does not work the remote may not be compatible with your TV.
Thanks for using FixYa.
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Jul 30, 2011
SOURCE: Hi, I noticed you answered
hi,
You didn't mensioned any where the brand and model number of the universal remote you have. Any why if your tv is not listed on the code list then there is one more way to find is that universal remote contain the code for your tv (ie code serch). Bellow i have adde the procedure for some of the universal remote. If you have another one then pls inform me.
If the remote is RCA:
1. Manually turn on the device you'll be using with the RCA universal remote.
2. Point the remote at the device.
3. Hold down the "Code Search" button found on the RCA remote. Hold down this button for about five seconds before moving on to the next step. Do not release the button yet.
4. Press the device button on the RCA remote for the electronic device that you turned on in Step 1
5. Let go of the "Code Search" button.
6. Start pressing the "Off/On" button located on the RCA remote. Press this button about once per second until the electronic device turns off. You may need to press that button 100 times before the device turns off.
7. Press "Enter" on the RCA remote after the device has turned off. Then, press "Off/On" again. If the device turns back on, the remote was programmed properly. You will need to restart the programming process if the device doesn't turn on.
IF Philips remote:
1. Press the "On" or "Power" button on the device you want to control with the Philips universal remote (such as the television set or cable box). The device must be on to use the code search function.
2. Hold down the "Code Search" button on your Philips universal remote. The red light on the remote will turn on. Continue holding the button for about ten seconds until the light stays on.
3. Press the button at the top of the Philips universal remote for the device from Step 1.
4. Start pressing the "Channel Up" button on the Philips universal remote until the device you turned on responds to the remote by changing the channel. Each time you push the button, the remote tests another code. You might have to press the button hundreds of times before the device responds.
5. Press "Mute" on the Philips universal remote to save the code on your remote.
IF Zenith remote: 1. Turn on the device you want to program, such as your TV or DVD player. 2. Look up the device codes for the device you want to control (see Resources section).
3. Press and hold the "Code Search" button on your Zenith remote until the indicator lights at the top of the remote turn on. The Code Search button is located on the upper-left side of the remote.
4. Press and release the device key, such as the "TV" key or the "DVD" key. These are located at the top of the Zenith remote.
5. Enter the three-digit device code. The indicator light turns off after you've entered the correct code.
6. Press the "Power" button in the upper-right corner of the remote. The device you are trying to control turns off.
ok
gopakumarg43
  • 76851 Answers
  • Posted on Aug 06, 2011
SOURCE: I can't find a remote
Hello
What is the model number of the Big Button remote control you uses? I've three models with me, but Electroview TV is not listed with none of them. Send me the exact model number of your remote please. Ok.
Hi i have an electroview tv and the remote stopped working. Purchased 2 universal remotes and neither did a autoscan tha worked and neither have electroview in their setup. Help please?
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
1helpful
The link to Fixya said free manual downloads. Could not find one for Electroview EV 32 tv.
don't know why you have difficulties
I went google and typed in -- manual for electroview ev 32 inch tv ---and got a page (pdf ) instruction manual 32"hd digital lcd-av-iq
the site is www.av-iq.com.au and there is the pdf manual ready to down load
I opened the site and waited for the down load
1helpful
How can I get a control code for a electroview tv model number VC42P?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Need codes for electroview tv
0039,0031,0035,0033.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
I need the code for an electroview ev32 tv remote control
3792,3722,3778. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
I have a westinghouse tv modle number LTV-27w2. I have a RCA universal remote control and I need the 3 diget code to program the tv.
Hello Sarheejackso, I don't have the direct code but I can tell you that this model uses SONY remote codes.
Have a Disney modle tv and need the code for a remote the remote is not working now modle # P1300NTV
Try setting it to cable remote--see manual or check back label for manufacturer's parts and accessories phone number.
Need codes for sylvania tv modle 6319CB using a
hi! i have here a code for your sylvania TV/VCR just try them 1145, 3095, hope this helps!!!! goodluck!!!
Top Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
