Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
Posted on Sep 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant find my security string - Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Techbelkin
Level 2:
Sergeant:
  • Expert 358 Answers
  • Posted on Oct 30, 2010
Techbelkin
Expert
Level 2:
Sergeant:
Answers
358
Questions
Helped
120893
Points
948
Ok here is your solution.
  1. let me know your Windows operating system
  2. check your Security type setting in your router
  3. channel and SSID sharing
  4. disable Firewall in router
Check your windows firewall and some anti virus who cant also block your signal.Go to setup page Belkin using 192.168.2.1
If you cant open it just reset router,go in the back of your router and locate the reset ping.
if you still cant do it just check your physical connection and go to command prompt using RUN and type CMD after ping router 192.168.2.1 and you will get a four answer and zero lose.
if you still cant do it ask me for a remote setup in your pc .
If you are able to open Belkin setup page using 192.168.2.1
Check all configurations and be sure you can setup it to wep64 bit security mode and your problem will be solved.
What is the security string number and where will I find it
The security string is the wireless router's Network Key (WEP, WPA, or WPA2 Encryption key)
1helpful
Cant get the buzz out of the high E string on my Epiphone les paul guitar
A buzz on one string is not due to a pickup fault. It's rather a too low string height at the nut or a string slot that is either too wide or has too deep of an angle towards the tuner. It could however be that you had the pickup too close to the high E string creating excessive string pull.
Cant remember pin number or security question , want to reset but cant without pin number??
yo can go to ninendo's site and call them they will ask you some questions and then they might pull some strings
How do i get my security string code
Hi
Connect Router - Computer (Wired)
OPEN RSP by typing 192.168.2.1. In the address bar of internet explorer
On the left side under wireless click security
You can view the string here
If it is a bunch of dots (WPA) Uncheck Obscure PSK
If it is WEP The key that is selected is youk Security String
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Security string
It seems that you are trying to connect the printer to wireless network with security.
Check the wireless network security settings. The printer requires the same key your system uses to connect to wireless network.
Thanks
6helpful
I have forgotten my security string onthe belkin
Connect Router - Computer ( Wired )
OPEN RSP by typing 192.168.2.1. in the address bar of internet explorer
My tele tuners have a slot in the tuners. I am
Usually you have either loops or little metal spools in loops at the end of the strings. The little spools are put down into the slots to secure the strings. If your old strings have the spools, you can remove them and put into your new strings.
1helpful
Cant get the new string to go thru holes help cant find the book
This string comes in a number of diameters, it sounds like the string you chose is just too large for the holes. Take your trimmer to the hardware store and select a string that fits in the hole.
2answers
1988 chevy corvette headlight repair
attach a string around the copper wire attached to the brush, place the brush back in the slot and pull both ends of the string out the side of the motor and tape securely, do the same with the other side. Work quickly before the tape lets go of the string.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
