Computers & Internet Logo
Posted on May 15, 2008
Error my system is giving error loading mp3plugin.dll
  • 12blake Jun 21, 2008
    when i turn my computer on it reads; error loading c:\progra~1\mywebs~1\bar\1.bin\mp3plugin.dll
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jun 25, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
4802
Points
23
Both of you need to do a virus scan. I prefer avast.com home edition. It is free and very powerful as well as easy to use. Then get ahold of an anti spyware program Webroot is an option. I prefer spybot search and destroy. It is also free. In that path I see "mywebs~1\bar" ... that is bad. Mywebsearch is spyware. Get rid of it.
Now, this error you are seeing may be from an anti-spyware or antivirus program already removing it but leaving the registry entry in tact. Simply run regedit and search for mp3plugin.dll and remove any instance of it in the registry. This should take care of your problem.
C:\Progra~1|Mywebs~1\bar\2.bin\MP3PLUGIN.dll
you can do the following,
open the run from start menu..
type "msconfig" and press OK...
goto the startup tab...
there uncheck entry having the same stuff as you have given in the question....(what is on the error)
click OK ..
restart the system it should work fine...
If this works please give a vote........
Need download of m3plugin.dll
Un-install the program through windows Add/remove programs.
See the link provided below;
progra-1-mywebs-1-bar-1-bin-mp3plugin-dll">http://en.kioskea.net/forum/affich-167900-c-progra-1-mywebs-1-bar-1-bin-mp3plugin-dll
Tip. This program allows adware and spy-ware into your system without you're knowledge. However if you still want it try a re-install after removing it at; http://download.mywebsearch.com/
Good luck.
Mike
1helpful
C:\PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL -- PLS HELP!! :(
Start
Control Panel
Add/Remove Programs
Select and remove the "My Web" application.
Restart your computer.
Run dll error loading 1`mywebs 3.bin`mp3plugin
Download spybot search and destroy from here:
http://www.safer-networking.org/index2.html
Install and run it.  Sound to me like you orphan files from spyware.
Dll MISSING:
reinstall drivers and utilities directly thru dos environment
13helpful
4answers
Mp3plugin.dll missing
hi,
http://www.fix-all-dll-errors.com/mp3plugin.dll/
u can go to this site...this site helps u in case of ur missing dll.... helped in my case :)
After windows xp loads on startup I get an error message it says: C:PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL I cannot find the file that might be corropted
Try this:
Click Start>Run>type "msconfig", then click the tab start-up and boot.ini, and see if you can find the C:PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL being loaded on start up, uncheck it then click okay and then restart the computer
32helpful
6answers
C:PROGA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL
I am running XP. I went to RUN - MSCONFIG, then go to START tab. You will find an entry for this DLL. Uncheck to box, choose APPLY, and restart your PC, the nagging pop up on restart should be gone.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
