iPhone Apps Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What reference software is there for my iphone?
tom sh
Level 3:
  • Master 1,141 Answers
  • Posted on Sep 06, 2010
tom sh
Master
Level 3:
Answers
1141
Questions
34
Helped
305972
Points
3513
Just search google and you'll find dozens of apps. One app that I really like is White Pages Mobile.This application allows you to search for people and businesses. Search for individuals and automatically add their information to your iPhone's contacts. You can also do a reverse phone lookup, which allows you to get a person's name based on their phone number. The application also includes maps and dierections.
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Jun 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
3776
Points
21
There are many apps. You can try using http://www.phonecodelookup.com.
IPhone shows recovery mode cannot start the phone
Your iPhone is stuck in DFU Mode.
Try this way:
1. Hold Power and Home button at the same time for exact 10 seconds
2. Release Power button while keep holding Home button.
If it does work,you can refer to this tutorial to use 3rd party software to do it automatically.
My iphone is blockout when i uninstall something then i restart it only apple logo is appear what can i do? pls help me
if install a non compatible application or software,that can cause malfunction,or if there are viruses frm your source,so hard reset,or it needs flashing,refer tonan expert
15helpful
4answers
The fucntions FIND ME and FIND MY FRIEND can run on iphone 3g??
you use function findme, ios5 can do anything what you want. or you can use software. Omegaspy software has this function too. you will search your friend by GPS function. this one be free. in addition, omegaspy has more function interesting at http://www.omegaspy.com
2helpful
2answers
I phone non responsive wont charge or turn on tried plugging it in via usb wall charger resetting computer, resetting iphone nothing, help
the only way of fixing this is to open up the iPhone and change thepart that connects to the cable, I'm sure you can find the partsomewhere and the internet. Like on iFixit
After u change the part of hardware everything was works smooth
How to Charge an iPhone
The easiest way to charge an iPhone is toplug it into the USB port of a computer or use the wall chargersupplied with it. But what if you want to charge it in the car with acar charger? I'm sure some of you have tried it. You can't because theiPhone doesn't charge like other normal USB devices. Just by supplying5 volts to the USB cable of the iPhone will not charge it. That's whymost car chargers will not work with the iPhone.2505609126_e52bf6af44_o.jpg
An iPhone taking charge.
Today I decided to discover the secret behind how the iPhoneinitiate its charging sequence. I tried plugging it into a few ordinaryUSB chargers which supplies 5 volts to pins 1 and 4 (refer diagrambelow). As expected, the iPhone refused to charge. Then I turned myattention to the iPhone's wall charger.
Image courtesy: wikipedia.com
Before I get into the interesting bits, a little basics here. AUSB charger supplies a regulated 5 volts to pins 1 and 4, with 1 being+5v and 4 being 0v. When a USB device is plugged in, it draws powerthrough pins 1 and 4. The device also draws power from there to chargeitself. So it would seem that just by supplying 5 volts to pins 1 and 4would be sufficient to charge a device. But that is not the case forthe iPhone (and I'm sure there are other devices that are built thatway too). Alright, enough of the basics, back to our experiment.
By measuring the output of all of the pins on the iPhone wallcharger, I realised that it gave a an additional reference voltage onpins 2 and 3 (Note: on normal USB car chargers, pins 2 and 3 are notconnected). On pin 2, with reference to ground, it was 2.5 volts. Onpin 3, with reference to ground, it was 1.8v. So I came up with thehypothesis that those reference voltages tell the iPhone to startcharging.
To test this hypothesis, I removed the reference voltages andsure enough, the iPhone refused to charge. Even removing either onewill result in the iPhone not charging. Interestingly, once the iPhoneis charging (with the reference voltages applied), I can remove thereference voltages and the iPhone will still keep on charging. But, ifI apply the charging voltage initially without the reference voltages,and then only after that I apply the reference voltages, the iPhonestill will not charge. So I came to the conclusion that the iPhone willonly charge if the reference voltages are present when the chargingvoltage is applied.
Updated schematic! I way way prefer to draw on paper than use a schematic software to draw nice schematics.
Using the voltage divider setup above, you'll be able to get the1.8v and the 2.5v reference voltages. The iPhone was only drawing about10 microAmps or 0.01mA from the reference voltages so large resistorvalues are acceptable. By supplying these reference voltages to pins 2and 3 of the USB connector, you should be able to fool your iPhone intothinking it is plugged into the wall charger and it should startcharging immediately, in theory. I mean, how hard is it to tricksomething that has no brain?
Anyways, a disclaimer here. I have not built a charger usingthis method yet so I cannot guarantee that it will work. And althoughit is almost impossible to destroy your iPhone by using the circuitabove, I hereby declare that I take no responsibility for whatever thathappens to your iPhone. This is just a proof-of-concept that I came upwith and will hopefully be trying it out very soon.
2helpful
2answers
Microfone don't work
you must chane a microphone on it,, go to the technician and refer for microphone problem, its not too expensive to take that
Openining iTunes in iPhone
I think the itunes you are referring above isn't the one from the iPhone, but the software one on your Computer.
When you connect your iPhone to your computer and start iTunes on the computer, if it doesn't already, then your iPhone will appear on the sidebar of the computer screen.
You will then be able to select the iPhone and copy songs to it etc. as well as have it copy contacts and e-mail settings from your computer.
Regards
Philip G0ISW
Top Apps Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an App Expert? Answer questions, earn points and help others
