Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
Posted on Sep 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change the belt on my bissell powertrak
Anonymous
Level 3:
  • Master 377 Answers
  • Posted on Sep 05, 2010
Anonymous
Master
Level 3:
Answers
377
Questions
0
Helped
125069
Points
1035
Give this a try.
http://www.ehow.com/how_2320063_replace-drive-belt-bissell-cleanview.html
3 Related Answers
Anonymous
  • 1673 Answers
  • Posted on Feb 14, 2008
SOURCE: vacuum
Check the brush roll first, if it is ok, then probably your motor has gone bad and will have to be replaced.
Anonymous
  • 199 Answers
  • Posted on Jun 14, 2009
SOURCE: powertrak bissel vacuum 6390/3910
it might have something stuck, check all the entrance suction sections, also give it little shake
Anonymous
  • 84 Answers
  • Posted on Aug 07, 2009
SOURCE: bissell powertrak is stuck in the high position,
Hello. The height of the wheels Will stay in the highest position until you release the handle release lever. At that time the adjustment will happen. I hope this helps. let me know.
Bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Powertrak bissel vacuum 6390/3910
2helpful
Bissell won't start
no reset (self resetting motor) Pull the plu,g leave it off for a day, plug it in a try it again tomorrow. If it doesn't work, the motor is gone
You also need to make sur ethat you get the vacuum back together correctly, some vacums put a swithc in there so that you can't hurt yourself while performing this repair
Screeching motor on a bissell 3595
Your motor is must likely bad and you would look at around $60 to $70 for a new one.
Vac quit working
I have a Bissell powerforce bagless 12 ampsthe brush will not turn, motor is working not sure if brush is gone or I need a new belt it shows spots of burns like the brush is jamed
Vacuum
1helpful
2answers
I have changed the belt, but....
Most likely needs a roller assembly. The roller assembly (older machines called this the beater bar) is made of plastic and doesn 't hold up well. It will freeze up and then the belt will start to burn. On mine, the belt continually comes off. Replacing the belt is only a temporary solution. Very poorly designed unit.
Top Bissell Vacuums Experts
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
