Have older canon laser class 7000 fax machine.
Light flashes and I get error code 330.
No longer have the manual
what is error code 330 and how do I fix it?
Thank you.
SOURCE: Canon fax/copier
1 Data Registation
2 Set
3 Set (when User Settings displayed..includes date, name etc.,)
4 Time & Date
5 Set etc..
SOURCE: Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
SOURCE: Canon Laser Class 7000 Fax won't print
Error code ## 322 indicates that the Fuser not heating (Usually cause by a Bad Fuser Module)
SOURCE: Canon Laser Class 7000 H12013 - need user manual - 'received in memory' on display
we have this machine! all you have to do is hit the green button and they will print out!
SOURCE: Canon Laser Class 9000 Super G3 Plain Paper Fax
I bought a Canon FaxPhone Super G3. I was told I could set the machine so that whe I send a fax from the machine, the machine can send a copy to an e-fax number. If possible, can you please explain how to do this?
Thanks,
Raul
