Getting worse, it intermittently starts jotting all over the screen and clicks on everything. I can't control it, I try to drag it back to where i want it and it acts like the pointer is stuck to one part of the screen. I tried cleaning the touchpad, turned down the sensitivity, and did a system restore. What really gets me is if i turn off the touchpad, the external mouse i plug in through the usb does the same thing. Any ideas would be greatly appreciated! Sandie
It sounds like you might have gotten attacked by a hacker ive seen them control screens
first indicator is when your comp slows down really quick then mouse goes hay wire then stops they some how got a trojan in your comp it sounds like to me heres what you if this is the colprit unplug internet from box then run your spyware every thing once disconnected from internet modem should return to the fast pace it was working at
if things return to normal quickly then they got you bugged a good solid firewall program will stop this hacks from getting in
