Heating & Cooling Logo
Posted on Aug 30, 2010
Need to replace the overload protector {compela t99000} on a window a/c but can't find the part for my a/c model any where. How can I find a different Brand for my unit. Carrier model bcc101d [73bcc110101d]. Btu/Hr 10100 Amp 9.9 ??? watts input 1100 EER 9.2 Motor-compressor desigh PSIG Hi 350 Lo 150 KPA Thermanllt protector Hi 2414 Lo 1034 ????
5 Related Answers
Anonymous
  • 75 Answers
  • Posted on Sep 23, 2007
SOURCE: Air Conditioner malfunction
Hi, Sounds like you have a short in the control circuit to me. Turn off all power going to the unit. Write down or otherwise mark the wires leaving the control board going to the thermostat. Remove them from the control board. Replace the fuse. Turn power back on and see if the fan still runs. If it does, check and or replace the heat limit switch that brings the fan on during the heat cycle. It may just need adjusted. If the fuse blows, I would think that the control board is probably bad. If it doesn't blow, Remove the thermostat. Leaving all thermostat wires open check them with an Ohm meter. There should be no continuity between them. Twist all the wires together at one end and ohm them again at the other end. You should have complete continuity on all wires. If the wiring checks out, down power the unit. Double check your wire colors and rewire the control board. With all wires open at the thermostat, turn the power back on. Touch the RED wire to the YELLOW wire. The Condensing unit should come on. Touch the RED wire to the GREEN wire. The fan should come on. Touch the RED wire to the WHITE wire. The heat should come on. Down power the unit. Replace the thermostat. Test unit. If the fuse has lasted ok but blows now it is either wired wrong at the Thermostat or the thermostat is bad. I hope I have helped. NOTE: If you can not understand these instructions. Call a licensed Heating / Air conditioning company. kstfas
Anonymous
  • 158 Answers
  • Posted on Jun 01, 2009
SOURCE: p8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
Anonymous
  • 10 Answers
  • Posted on Jun 07, 2009
SOURCE: Does anyone know the power consumption in watts
yeah find the data plate on the ac muliply the RLA or amps by the voltage of the unit example 15 amps times 120volts= 1800 watts. hope this helps
Anonymous
  • 3 Answers
  • Posted on Jun 16, 2009
SOURCE: How many BTUs does this unit have?
The M3X05F2A is a 5000 BTU unit.
Anonymous
  • 340 Answers
  • Posted on Jun 17, 2009
SOURCE: Looking for Watts and EER rating.
try ruud.com tech support or google . Tom
Top Heating & Cooling Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
john h
