Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Aug 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does the code ld stand for - Whirlpool Cabrio WTW6600SBT Top Load Washer
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Aug 28, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2177065
Points
26471
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
3helpful
I have an error code that says "LD", what does
The LD stands for Long Drain and it flashes when the water level does not change after the drain pump is on. Check to see if the drain hose or drain pump is clogged or is the drain hose situated too high.
1helpful
E1 fault no manual
Hi, use this table to find and know more about codes.When you get into the link,scroll you will see all codes and solution.
(repairclinic.com/0078.asp).
Take care.
3helpful
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
1helpful
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
2helpful
Ld error code on kenmore oasis
ld stands for long drain. If you can remove the bottom panel you will see the pump in the middle front which has a clean out you can unscrew. There is usually obstructions in the clean out such as a sock causing the long drain. When u remove the clean out cover alot of water will come out so a wet vac comes in handy.
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
1helpful
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
2answers
"E 1 code error
The fault is that the anti flood device is activating, you have a leak somewhere in the base of machine. Regards Engineer
Narseman
