Bissell 16N5 Upright Vacuum Logo
Posted on Aug 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset button for bissell - Bissell 16N5 Upright Vacuum
Anonymous
Level 2:
  • Expert 276 Answers
  • Posted on Nov 16, 2010
Anonymous
Expert
Level 2:
Answers
276
Questions
0
Helped
104032
Points
585
- Make sure the power cord is plugged into a functioning outlet to check for power.
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
- With the machine turned off and unplugged, check the pre-motor filter and the Airetight™ HEPA filter for debris. Reduced air flow from dirty filters or clogs will put greater stress on the motor, increasing the possibility for overheating. The pre-motor filter is located underneath the canister of the vacuum in the pull out tray labeled "filter". This may be hand washed in cold water with mild detergent. Reinstall this filter when it is completely dry. The Airetight™ HEPA filter cartridge needs to be replaced and cannot be washed. This is located on the side of the machine inside the filter grill.
CLEARING CLOGS
NOTE: Ensure the machine is turned off and is unplugged before checking the following.
DIRT CUP AREA
- Empty the dirt cup. Remove the lower portion of the cup and clean the screen and check the center tubes for dirt accumulation.
- Check the dirt inlet. This is the opening located behind the canister and is only visible once the canister is taken off the machine.
UPPER HOSE
- Detach the hose from the machine by twisting the hose collar counterclockwise. Push a broomstick into the hose to push any obstruction to the end of the hose where it can be removed.
- Check the clear diverter area at the back of the machine. When the hose wand is removed from the base, the diverter should be in the up position. If a clog is visible near the diverter, remove the divertor cover by removing 7 screws and clear the obstruction.
NOTE: Be careful not to dislodge the gasket.
LOWER HOSE
- Recline the machine back and roll it over so the backside is facing up. Remove the bottom 4 screws from the diverter cover to loosen, and straighten the foot hose. Look through the hose for obstructions. Push a broomstick through the lower hose to unclog this. (Any obstruction should exit through the suction path at the brush roller).
NOTE: The Healthy Home Vacuum is equipped with a Thermal Protector feature to prevent the motor from overheating. If the motor becomes too warm, the thermal Protectors will activate and the machine will shut off automatically. If the Thermal Protectors activate, please do the following:
- Turn off and unplug the vacuum. Thermal Protectors will reset automatically in approximately 30 minutes.
- Clear any clogs.
If you continue to experience no power, please take your machine to a local BISSELL Authorized Service Center. BISSELL supports your machine with a five year warranty.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
Cant find reset button
Hey Troy, the PowerForce Turbo Helix doesn't have a reset button. You may want to have a Qualified Technician at at BISSELL Authorized Service Center inspect your vacuum.
Here's a quick link to assist you in locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
3helpful
2helpful
Brushes not rotating
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
45wtw
2helpful
Bissell won't start
no reset (self resetting motor) Pull the plu,g leave it off for a day, plug it in a try it again tomorrow. If it doesn't work, the motor is gone
You also need to make sur ethat you get the vacuum back together correctly, some vacums put a swithc in there so that you can't hurt yourself while performing this repair
3helpful
2answers
The vacuum stopped running and won't turn back on?
While there's no reset button it's not uncommon for the internal thermal switch to trip to an "open" position. This internal, no-access-switch opens when the motor gets hot, it protects the motor from overheating to the point of failure. Bissell's website states that if the thermal switch is tripped let the vacuumm sit for a half hour and then it try it again.
If it doesn't work you might then try Tech610's suggestions.
Reset button
Do the brush rolls turn ok? The brush roll motor may be bad.
Top Bissell Vacuums Experts
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
