Do you have the complete E-Nr or Model Number available, and I will try to see if I have the pdf file for it
OK...the owners manual is located at the following website......
http://www.managemylife.com/mmh/owner_ma...
this is a 44 page pdf file, but it only states pretty much the basics.....however I was able to track down precise info that will hopefully help you......
Here is the error code and things to check on your oven.
Error Code: F41 Cause: Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; Defective latch motor or its wiring.
Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check that the solder joints in header P24 on the power board are not broken. 5. Check P10 connector and check if latch motor wire is
I hope this helps
E-NR. HBL765AUC/03
E-NR. HBL765AUC/03
