SOURCE: Scanning multiple pages
Go to the Epson web site and download the Reference Guide that they provide free. This guide includes instructions on using the scanner in Professional mode so you scan multiple images simultaneously
SOURCE: My Epson cx 4200 won't
It's highly likely that you either have a foreign object down the paper feed tray or the guides are incorrectly set...
Hopefully one of these will solve this:
1. Remove any paper, tape down the scanner lid and
gently tip your printer upside down and give it a GENTLE shake to see if anything drops out. This is really only something I'd recommend for someone strong and careful so take your time.
2. Check for any jammed foreign objects such as pens, paper clips, etc...that have fallen down into the printer. The place to look is wherever the paper seems to be bunching up most as it goes through
3. Make sure you're inserting the paper, with the guides set to the correct width and not loose. The guides help correct any issues with skew as the paper is pulled in, so this may correct any other issues.
Hope one of these helps..
SOURCE: Could not read the ICC profile. Saving image canceled.
ICC = International Color Consortium.
The ICC's should be installed in the default printer directory.
Also, you may want to check the printer profile. In printer properties under the "color management" tab check to see if automatic or manual is highlighted. If manual is highlighted, be sure the print profile matches that of the paper you are using. You can select any of the included profiles as the default or add your own from a third source. Such third-source profiles are most often specified by your software provider
SOURCE: Will not print
check the cables that connecting pc with the printer
Testimonial: "Yes, That was a simple solution. Thanks KT"
