Northstar Professional Series Pressure Washer 4000 PSI Logo
Posted on Aug 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant start the unit ,there is to much pressure on the pull chord when water is hooked up.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
466
Points
I have also had this issue if you squeez the triger on the the gun while you pull the start you will be ok, I know this is ghetto but otherwise a quick fix lol
John Trevino
Level 3:
  • Northstar Master 1,420 Answers
  • Posted on Aug 25, 2010
John Trevino
Northstar Master
Level 3:
Answers
1420
Questions
Helped
1029419
Points
3200
Trying to start a pressure washer with water supply on and gun trigger off will be a difficult task. It could be comparred to trying to start a lawn mower with the mower in tall grass. Place the mower on the drive or walkway and pulling the rope to start the engine is much easier. It is easy to start your pressure washer with no water in the system however there is a remote possibility that you could overheat the seals if you take too long to turn on the water. It is a little more difficult to start the washer with water supply on and someone holding the trigger to wand open. This will prevents pressure from building and making engine hard to start. You will not damage your washer if you start it with water supply off if you flood the pump and pressure hose with water first . Here is the procedure I use if i am working alone. I trun on the water to pump and open trigger to gun to allow water to flow into pump and pressure hose. Turn off water (leaving the water supply on will make it a little harder to pull starter). Start engine while holding trigger to gun open. When engine starts release gun causing unloader to activate circulating water in pump. Now turn on water and you are ready to work. If your system is under warranty however, I would advise to use the starting procedure outlined by mfg (hold open trigger to gun however). To get the longest life from unit try using it at say 75% of capacity or lower if your can and use max pressure on the tuffest jobs. Leaving your washer at full pressure for all jobs is like driving your car at 100 mph everywhere your go. Good luck.
Top Northstar Garden Experts
john h
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Northstar Garden Expert? Answer questions, earn points and help others
