SOURCE: removing tractor deck to change belt and blades?
if i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
