Garden Logo
Posted on Aug 18, 2010
I was given a Kohler hot tub by a friend. It has a Sta-Rite Pump Model #KS110HBD. We've installed it on out back deck. Have everything put together, ran a new electrical line and every time we plug the hot tup into the outlet something inside the control box trips. When we push the reset button it trips every single time. What could the problem be. We know it's not the electrical line because we've already tested it and it's good. Please, we are at a loss for ideas.
5 Related Answers
Anonymous
  • 148 Answers
  • Posted on Dec 21, 2007
SOURCE: kenmore dishwasher model 665 motherboard
relay or sensor
Anonymous
  • Posted on Mar 31, 2008
SOURCE: haier window air conditioner
I suggest you check the ground of the wall socket. Many three proung sockets are not grounded.
Anonymous
  • 44 Answers
  • Posted on Mar 24, 2009
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
clay
  • 74 Answers
  • Posted on Apr 13, 2009
SOURCE: how do you know if the rapid heater for jacuzzi tub is bad?
all heaters have a thermostat (or multiple) and heating elements.
Start by removing the elements and seeing if they are burnt through.  If so, replace.
If they look fine then replace the thermostat(s).
Both are relatively easy and cheap to perform.
Remember to turn off the power and water to the heater and drain the unit completely before doing any servicing.
libaredneck
james
  • 125 Answers
  • Posted on May 05, 2009
SOURCE: fuse blew, replaced with new, and now electric clutch will not work
sounds like you probably need a new clutch. they short out internally and blows the fuse
Top Garden Experts
ADMIN Andrew
ADMIN Andrew
john h
CJ Rock
CJ Rock
