Fujitsu LifeBook A1110 Notebook Logo
Anonymous Posted on Aug 14, 2010
How do i replace my harddrive on mu fujistsu A1110 and also is there a way to get the computers speakers louder...ive turned it up to the highest level and it still seems like lower volume...thanks
Anonymous
Level 3:
  • Master 6,831 Answers
  • Posted on Aug 14, 2010
Anonymous
Master
Level 3:
Answers
6831
Questions
0
Helped
1241418
Points
16135
Hello
Regarding the sound issue:
If the sound icon in the lower right corner is set to max, it is the loudest this computer will go.
Now, installing a new Hard drive. Just follow the steps below.
  1. Step 1 Make backup copies of any important files or folders that you will still need to an external source such as a flash drive or CD-RW. Power off the Fujitsu laptop and close the screen lid.
  2. Step 2 Turn the Fujitsu laptop over so that you can see the battery port on the bottom side of the case. Press down on the release latch for the battery. Lift the battery out of the laptop case and set it aside.
  3. Step 3 Find the rectangular plastic cover at the bottom edge of the case that covers the hard drivehow do i replace my - mag-glass_10x10.gif. Remove the screw at the left side of the cover. Slide the cover to the right and pull it off of the case.
  4. Step 4 Take out the two screws holding the hard drive carriage to the case. Pull the carriage containing the hard drive out toward the left and then remove it from the case. Slide the hard drive out of the carriage.
  5. Step 5 Put the replacement hard drive into the carriage. Push the carriage back into the open port on the Fujitsu laptop and then push it to the right. Reinstall the two screws that hold the carriage into place.
  6. Step 6 Set the plastic cover back over the hard drive and carriage assembly. Reattach the screw at the left side of the plastic cover. Push the battery back into its port until the release latch clicks.
  7. Step 7 Turn the Fujitsu laptop back over and open up the screen lid. Power the laptop on. Put the operating system recovery CD that came with the laptop into the disc drive. Follow the instructions that will appear on the screen to install the operating system on the new hard drive.
This should be sufficient. Please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
  • Yiu Bosco Dec 31, 2013
    I got a problem, after I put the recovery CD and use the recovery of system tool a message came out "partition not be created"
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
