PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pendrive cannot be formatted - PNY 4GB USB 2.0 Flash Drive - Grey/Black
Anonymous
Level 2:
  • Expert 237 Answers
  • Posted on Aug 12, 2010
Anonymous
Expert
Level 2:
Answers
237
Questions
0
Helped
51617
Points
740
Some file may be protected one. unprotect them
dele files one by one
go to properties by right click
then tools then error checking then click chek now
after checking errors
try to format it
1helpful
I have 8gb kingston pendrive..and i set my pendrive drive name to 'myname'.i already used my pendrive 7.4gb.and got a lots important files..when i plug in the pendrive,it will automatic install driver...
yes your pendrive is attactked by a severe virus.......you need format it you can do only one thing click on format option or restart the pc then press f8 thenan stat windows setup when you reach the formatting option then only format that pendrive.............
2helpful
I have a Sandisk 4GB pendrive. It is affected by some virus. So i am not able to open and format my pendrive. What shall i do to recover my pendrive?
you can format your pendrive.
follow the steps to format:
  1. right click on my computer.
  2. select manage.
  3. select disk management.
  4. on right side select your drive.
    (tips. your pendrive is in removable media. so see in this group)
  5. right on drive,you want to format.
  6. then select format.
If it doesn't work then try out this steps on safe mode.
if it helps, pls rate it... ; ) thank you.
2answers
My kingston 32gb pendrive not format , how to format my pendrive please give me step by step solution thanks & reghardes subhash
normaly your pendrive not formated so cmd (command prompt) use.
Run - cmd (type) than enter
format (pendrive colon) than enter
continue process which computer show
your pendrive is formated.
2answers
My mosearbaer pen drive cant be formatted and we also cant delete any files in the pendrive???
virus in your pendrive.
so format your pendrive dos command
start than run than type cmd than enter
ok and command type is
format (your pendrive colon) enter
i sure your pendrive format.
2answers
My pendrive is not working properly whenever i double click on it , it shows u want to format it but when i click yes it is not getting formatted
may be ur pendrive is corrupted...with virus/trojen
try conencting it on another machine...and do a virus scan...pendrives are like floppy drives...they catch the flu of virus/trojen very frequently...unlike CDs...
Hello Sir I have a 2gb kingstone pendrive when i insert in my pc and after i just open but there is a problem they want first formate and than open any folder when i formate my pendrive they erro was ...
your pendrive is infected with Autorun virus
to remove this virus install malwarebytes (It is a antimalware software )
scan your whole computer with your pendrive
when you remove the virus format your pendrive .
If the above method is not work
Try to format in other operating system
like in vista or in 7 but not in xp
2answers
Problem of Pendrive
check pendrive with other computers.If it is not working then pendrive having problem.
Otherwise check your smps, some times if you connect more peripherals,
pendrive will not detect because of power problem.
2answers
Solution
Pendrive is probably formatted with a non-Macintosh format. Reformat pen drive using Disk Utility, and full capacity will show.
2helpful
2answers
My usb device is not formatting
it is due to virus problem take this pendrive to another computer and u can do the formatting. if that is not possible then try deleting some files nad do the formatting or format ur machine and do the formatting or none of the solution works then the usb disk is corrupted.
51helpful
6answers
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
