Posted on Nov 18, 2017
Hi. I ordered an Alesis DM5 electronic drum kit with Surge Symbals. Everything is plugged in correctly and is all powered on, but it won't make any noise through the headphones. The only thing being recognized is the hi hat pedal, but even that won't make a noise. I've been working on it for hours and I can't get it to work.
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Aug 03, 2007
SOURCE: NO BACKGROUND LIGHT
Hi Peter...I'm shameful to admit that I have very little optimism that my suggestion will remedy your issue, but let me begin by sharing my reasoning with you. According to the chronology of events, your backlight only began malfunctioning after your soldering mend. So let's just keep it simple and deduce that the solder you applied may be shorting another connection, or you may have applied too much heat for too long a period, which may have caused some delamination of the board, or perhaps, melted pre-existing solder which in turn ran and caused a short. So, if you understand and agree with my reasoning, and would like to confirm it by process of elimination, here is my pitiful suggestion..... Let's open your player and reverse your fix while simultaneously employing the art of investigation. Before "getting in there", I highly suggest that you have a magnifying glass handy, or a pair of reading glasses with adequate magnification. If possible, I suggest doing this outdoors when there is adequate natural sunlight. If you must do this in artificial lighting, try to avoid fluorescent tubes as your light source, the exception being Compact Fluorescent Bulbs. Begin by using a flat and stable surface, covered with a neatly flattened towel. The purpose of the towel is to prevent any accidentally dropped screws or parts from bouncing into a proverbial haystack which you will then, have to find a needle in. After opening your player, carefully and methodically examine the immediate area that you worked on, while mentally recalling the possible defects that I mentioned in the 2nd paragraph. Do you see any evidence of any of the scenarios? Do you see any, regardless of how slight, discoloration of the board which could indicate delamination? Manipulate the lighting on the board by turning and skewing your view of it, again, looking for signs of possible delamination. If you easily detect what you think might be delamination, let's just call it quits, reassemble your player and celebrate the fact that your player can still perform all of it's primary functions, which were good enough to make you buy it. Unless of course, you bought it for the backlight. If you see no indication of any of the possible defects mentioned, and would like to continue, our next goal is to remove all of the solder that you applied in the smallest increments possible. Begin by visually scrutinizing your solder, until you can pinpoint a specific area that looks like a prime suspect in causing a short and begin there. If your solder cannot be easily manipulated or removed, you will need to purchase a Solder Wick, which, as the name implies, will allow you to absorb and pull away solder as it liquifies. Keep a mental tab of how much heat you are applying, and for what duration, to minimize possible delamination. Once you have your most likely suspected area of conflict cleaned up, minimally, but adequately reassemble your player and power it up to see if your backlight is once again....backlighting. If it does light properly, and you believe that your headphone jack is adequately secured, pack it up and run for the hills while listening to backlit music. However, if your backlight is still defective, repeat the process, starting with your next most likely culprit area. Well, I've given you enough information enabling you to know exactly what my theory and fall-into-place solution is. If it turns out that I have provided the only response to your issue, please don't use that as justification to follow my instructions. However, if you choose to give it a go, re-read my 1st paragraph immediately prior to commencement.....Please update your post with any developments, whether positive or negative so that I may learn from this too....good luck my friend.
philw1964200
Phil Whisenant
  • 163 Answers
  • Posted on Aug 28, 2009
SOURCE: Cannot Upgrade Alesis dm5 drum module. Im using midi-ox and a usb to midi converter to upgrade the dm5 module from the provided update on the alesis website.
I am a drummer and use an Alesis to lay down demo tracks at home. Alesis I have found are the very hardest to update.If I were you first I would do a Google search for updates for your model and if you do not find anything then contact Alesis support and ask them if there are updates for the DM-5 and where you can get them from. If there are no updates I am sorry to say that you will most likely have to purchase a newer model.
I wish you the best of luck!!
Phil
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Anonymous
  • 496 Answers
  • Posted on Sep 24, 2009
SOURCE: no sound from my ipod using headphones or car kit
sounds like your headphone jack might be out unless the sound is comming out from the headphone jack when plugged into the pc
Anonymous
  • Posted on Dec 17, 2012
SOURCE: Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
shadman1
Tony Shadman
  • Posted on Jun 27, 2015
SOURCE: I have an IED 11
I had the same problem. There is a switch on the back of the module for whether you want the kick drum to be controlled by a pedal or a trigger pad. Easy to miss the switch but an easy fix!
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
