Philips 32FD9954 32 in. HD-Ready Plasma Television Logo
Posted on Aug 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't find where to hook up tv coax. - Philips 32FD9954 32 in. HD-Ready Plasma Television
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Nov 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
5110
Points
22
The Phillips 32FD9954 is an "HD Ready" display. It requires the optional FTR9964 "E-Box" to access the advanced features like PIP and off the air tuning. Unfortunately, the E-Box is NTSC (analog) and would require an additional converter box to receive today's over-the-air digital broadcasts.
The 32FD9954 has copious inputs, so possible tuner solutions include a satellite receiver, digital cable box or a VCR with composite or S-Video outputs. There are VGA and DVI inputs, so hooking it up to a computer with a tuner card is also an option. The computer hookup would allow you to stream video from the Internet. NetFlix is cheaper than cable!
Donnie Wayne Sharp
Level 2:
  • Expert 132 Answers
  • Posted on Aug 08, 2010
Donnie Wayne Sharp
Expert
Level 2:
Answers
132
Questions
0
Helped
26810
Points
400
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
1helpful
Hook up vcr to tv with converter box
Coax from wall to in on box,
coax out from box to in on the VCR.
coax out on Vcr to the in on the TV.
TV on the correct channel and whatever channel the box is on can be recorded and also seen at the set.
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
1helpful
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Hook Up Panasonci DVD-S29 to RCA F20539DG TV (Tv coax, DVD RCA's)
You will need an RF converter, if they still sell them. Radio Shack, Best Buy etc. did sell them for about $20.
How to i hook-up a directv dvr plus to two tv's?
plug one tv using coax (screw in cable). plug the other using composite video cables( yellow, red, white). It will be easy to connect the tv that's the farthest with coax, its cheaper to purchase 50ft of coax vs 50ft of composite video.
How do I hook up my Dish Satelite to it?
should go from your satellite to dish box might say sat on bck of box then the next [connection think says tv that should go to tv itsself or dvd vcr whatever ur hooking up to it then from that point hook it to ur tv
Trying to hook up your DV220SL8 DVD/CD Video Cassette Recorder. I have an antenna coming in coax but there are no places to plug any of the jacks on the tv.
There are two ways of solving this problem
1.It seems to me that you need an RF Modulator Box. What this does is convert the RCA cables (Yellow,White,Red cables) into coax. You buy the box then plug you antenna and RCA cables into the box. The box has a coax output that goes to your TV. You can then switch from VCR\DVD to antenna.
2. I dont know if your VCR/DVD has it but try hooking up your antenna to the VCR coax INPUT and then hook up your TV to the coax OUTPUT. Both Coax INPUT and Coax OUTPUT should be on the back of the VCR/DVD device. Your going to need an extra Coax wire for this.
Hope this helps
Thanks for reading!
hope this helps
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Top Philips Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
