A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness
To use your device in dark environments, enable the automatic backlighting feature:
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
then select Settings > Battery & Display.
to return to the Jump screen and save your setting.
Tips:
button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
i just bought a used sk and the backlight doesnt work at all u think u could help me out how to fix it
same thing
