Frigidaire GLEQ2152ES Electric Dryer Logo
Posted on Jul 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Err68 dryer stops and said E68
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Jul 22, 2010
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1252152
Points
12716
Hi
Error E68 on Frigidaire dryer means that One of the keys (buttons) is stuck closed (active). Please check whether any button is pressed or stuck. Also try removing the lint filter and clean the contacts of the inside of the filter.
Try performing function test to check which button is at fault. Enter function test mode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists then you'll need to replace the electronic control.
Function Test--
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and “rES” will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED’s will rapidly flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation.
Please post back for any further assistance.
Daniel
  • lvbr Nov 20, 2010
    THANK YOU!!!! I was going INSANE with the constant beeping. I thought my dryer was possessed.
1helpful
What does code E68 mean?
Hello Erik;
My name is Peter. I am a retired field service appliance technician.
The code E68 appears when one of the buttons on the keypad is stuck in the down position. This is a common error with several different Frigidaire dryer models and tends to occur when the dryer is five or more years old. You may be able to un-stick the offending key manually. If not, you will need to replace the entire keypad.
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 06, 2012 • Dryers
1helpful
Frigidaire affinity XD71702132 error 68
Please click the link below to see my answer to a similar E68 question on fixya:
https://www.fixya.com/support/t10225683-error_code_e68_frigidaire_affinity
5helpful
2answers
E68 error message
The code is for a stuck button on control panel. You will need to replace the control panel
The dryer gives E68 it starts running dor 30
the code 68 on the aeq7000es series is indicative of stuck buttons [your control buttons on the front]They sometimes stick in the closed position or go open [fail] and I have found the bad switch and replaced just the bad switch[ there should be a series of test to determine which switch button is bad] and if the switch buttons are testing good ,then it's control panel time. The control panels are about $150.00 on ebay ,sometimes you can find a "make offer" deal,but their few and far between.
I have an err68? How do I repair?
E68 One of the keys (buttons) is Enter function testmode and perform key stuck closed (active). (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists, replace electronic control.
Sep 21, 2009 • Dryers
11helpful
Dryer keeps stopping error code e68
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Hi, I am getting an error E68 on my dryer
Hi have you tried putting less into the machine as this could be a simple over weight problem
Top Frigidaire Dryers Experts
jdthefixer
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
