Hitachi HDT725050VLAT80 500 GB EIDE Hard Drive Logo
Posted on Jun 17, 2010
Hitachi insert a disk problem
My system recognizes a hitachi hard drive when its switched on but when it gets to desktop it is recognized as a removable drive
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Apr 16, 2009
SOURCE: Computer doesn't recognize my external HD
Test the HD on a different computer, if you get same problem, then the disk can be faulty. Backup your data ASAP, then replace either exernal hard disk enclosure, or the hard disk drive, depending on what is faulty.
If you get no problem on other computers, then the system is causing the problem. In that case try doing a system restore to a recent date before the problem started. If that does not work, then you will have to reinstall the system.
Anonymous
  • 183 Answers
  • Posted on Oct 13, 2009
SOURCE: A new hard disk drive, Hitachi part
Hello there DLBurkhart.
Here's your geek-steer ...
"...is emitting strange whining sounds every now and then ... Is this strange noise a sign of an impending problem?" == EVERY strange HDD noise is ALWAYS a sign of impending failure.
Peform a "Check Disk" on it ...
chkdsk DRIVE_LETTER /X /R
  • There should be NO surface errors if it's new(er).
  • Regardless, if it's new, then immediately insist upon a replacement.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Testimonial: "Straightforward advice, actually reads the problem pays attention to what you say rather than skimming and throwing out half-hearted recommendations."
Anonymous
  • 3278 Answers
  • Posted on Nov 07, 2009
SOURCE: Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Hello.
For most IDE drives, if you REMOVE the jumper, the drive becomes a slave. But, you'll also need to change "drive 1" in your BIOS to recognize the second drive.
If you look on the drive, there should be a scheme as to the mode (Master, Slave,etc.).
Hope this helps.
Anonymous
  • 14 Answers
  • Posted on Apr 09, 2010
SOURCE: Hitachi 250GB external hard drive on Mac OSX problem
try to format it in other way like ntfs or fat32....
Rinoo Kumari
  • 2973 Answers
  • Posted on Sep 19, 2010
SOURCE: I'm trying to use my
Try attaching the Hitachi to a different USB port. After connecting to the USB port, go to Control Panel->Administrative tools->Computer Management->Disc Management. And see if it is visible here? If yes, then you can do what you want with it. If not, then I am sorry about the HDD. I think it is still under warranty. Please make use of the warranty and return the HDD and ask for a replacement. It being a USB HDD there is nothing wrong you could have done to it. In an internal HDD you could have connected the data cable the wrong way and have caused the damage, but not in a USB HDD. So the replacement process should be smaller and smoother.
Top Hitachi Computers & Internet Experts
Rommel Balcita
jdthefixer
Grand Canyon Tech
Grand Canyon Tech
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
