Microsoft Windows XP Home Edition Logo
Robin Ray Derro Posted on Jun 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to create bootable cd? - Microsoft Windows XP Home Edition
  • Robin Ray Derro
    Robin Ray Derro Jun 02, 2010
    what version of nero did you used?
Anonymous
Level 2:
  • Expert 128 Answers
  • Posted on Jun 01, 2010
Anonymous
Expert
Level 2:
Answers
128
Questions
Helped
48330
Points
270
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip ~1.34KB)
2.) Extract the BootSector file (boot.ima) from bootfiles-from-tacktech-website.zip
into the folder C:\OS\BOOT
Start Nero Burning ROM.
Select File > New... from the menu.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click thow to create bootable cd? - 9e7f187.pngOpen button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check w more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Serverhow to create bootable cd? - 6519cde.pngels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer,how to create bootable cd? - 5980e4a.pngn
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possiblehow to create bootable cd? - 53647cb.png/>- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything how to create bootable cd? - ea7a68a.pnger and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Regards
Pcs365.8
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jun 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
3314
Points
25
Best way is to use nlite!
just copy windows cd cotent to disk, open nlite, select i386 0r amd64 as source go forward and select only make a bootable iso.
select option yo want and you are done! you jus have to burn it on a cd dvd.
this program can be used to integrate addons, service packs hotfixes, and driver to a standard installatio disk.
you can allso create an unattende version of your windows copy!
1 Related Answer
Anonymous
  • 151 Answers
  • Posted on Sep 28, 2007
SOURCE: how to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
Create bootable XP disc
Dell only allows you to make 1 BACKUP Disk. but any Genuine XP iso. is bootable.... infact any genuine OS.iso is bootable... and DELL should auto boot to DVD when you insert the media, and reboot.
Need to reformat my pc,but the bootable cd is deffect, window xp how to recover my bootable cd
why don't try with bootable USB stick ( 4GB) . u have alot of programs to make bootable USB like (rufus_v1.4.1). for more search in google :" create bootable USB windows XP" (something like this ). I hope i helped u. Respect !
Windows xp boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
1. Place diskette in the computer.
2. Open My Computer, right-click the A: drive and click Format.
3. In the Format window, check Create an MS-DOS startup disk.
4. Click Start
Create Windows XP Setup diskettes
Microsoft is beginning to phase out bootable floppy diskettes in favor of bootable CD discs and has not included a method of easily creating a bootable floppy diskette in Windows XP or from the CD. However, Microsoft has downloads available for users who still need to create bootable diskettes to install (not upgrade) Windows XP. These downloads can be found through KB310994.
hope this helps
I'm looking for a recovery disk for my MSI ms-1013 notebook.
unless you made one or you were provided with an installation disk
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
4. Click Start
hope this helps you
2answers
2answers
Cannot remember password
If you forgot Windows password, you can create a Windows password reset bootable CD/DVD or USB flash drive to reset your lost or forgotten Windows password, i have created a bootable CD with the tool Windows Password Breaker and reset my administrator password successfully.
Where do i find a boot up disk for my hp pavilion running xp? currently the unit starts to boot and then restarts.
Trying to get a bootable XP CD is difficult if not impossible to purchase. Therefore you might want to create one.
I just recently created a bootable XP CD since I was building a new computer and wanted to be able to boot from a CD.
The following URL is a blog I found that helped me create my bootable CD
Create Bootable XP CD
You'll need an XP CD in order to copy the files to your hard disk and to extract the boot image from.
I already had an XP SP3 disk and didn't need to perform the "merging" like the link above does. I did find and download iso buster (freeware) in order to extract the microsoft boot image file.
I used the Roxio steps to create my CD. My version of Roxio was slightly different so the instructions were not 100% correct but I was able to figure things out.
If you successfully create your bootable XP CD you will still need your license key to install just as if it came right from the factory
2answers
Reset bios without running hard disk first
2 options:
  1. create a bootable cd with the bios rom file, and a dos based flash utility (included with bios download). Boot to cd and flash.
  2. Connect a usb floppy drive and create bootable floppy. Copy rom file and flash utility to floppy, boot to floppy and flash......option 2 may be easier if you are not familiar with creating bootable cd's.......Let me know if this helps or not.
94helpful
12answers
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Top Microsoft Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
