*To Manually program the AT&T universal remote control to your
TV here are the steps
Factory Reset the AT&T Remote Control:
* Press the ATT button and the OK button at the same time for 2-3 sec. release them at the same time. The ATT button will blink twice then enter the code 922. The ATT button will blink Thrice. IF not repeat the step
* Press the ATT button then check all the function of the remote (Volume, Channel, Menu, Guide)
Note: you will see that the max volume is 25. Dont worry its the volume of the receiver
To Program Your TV:
* Press the TV button and the OK button at the same time for 2-3 sec. release them at the same time. The TV button will blink twice then enter the code. Click Here to see the manucafturers list of codes. After Entering the code TV button will blink thrice. IF not repeat the step
Note: After you program the tv make sure to press the ATT button. then now check all the function of the remote. Follow the instruction and it will work. If you press the power button the TV and ATT Recievier will turn on and off at the same time
Thanks for using Fixya.
Hi! i have here a couple of codes for your RCA tv for Uverse, just try them 1143, 1196, 1241, 1242, hope this works!!! goodluck!!!
