my benq lcd monitor dont have power at all. i plan to see it if it is just the fuse.i already unscrewed my lcd but it is hard to open the case. can you help me to open it. i just worry that it may lead to cracks or damage at all
and above prob.... any ideas on what the possible cause of having no power at all?
Just managed to open a FP17G+ monitor. My hope is that FP17G is similar and that this comes in handy.
There are 5 screws holding the casing together. Four are in the corners (black screws on my monitor). The 5th is right under the monitor stand (silver screw on my monitor.
To open the monitor, I had to:
1) Remove the monitor stand. To do so, you need to take out the two screws at the point where the base connects to the monitor (right above the pivot point) and slide out the monitor stand. THis should give you enough space to take out the 5th screw.
2) Unscrew the five remaining screws on the back of the monitor.
3) At the bottom edge of the monitor, there are two gaps between the front and back plastic panels of the monitor. You can place a wide screwdriver in this gap and gently pry apart the front and back of the monitor. Continue around the edge and the monitor will be open.
Best of luck... If you figure out what is wrong inside, let us know (I am trying to fix the same problem).
