An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The all-in-one cannot copy, receive faxes, or print.
Solution
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the all-in-one.
Hope it could help....!
Is your carriage move freely....if not, maybe put a little bit of oil on it and try it again....
The last thing that i'd could tell you is to try by puting hot water, but be very carefull to not put water on your contact, into the buse of the service station...Maybe there's dry ink in your rubber tube....
Maybe you should bring it to a service tech for....You may need a good clean up....
Amigo, só para ajudar a divulgar aos usuários de Bulk. Se o código de
erro 0xc18xxxxx ou 0xc19xxxxx do sistema de tinta da impressora HP
Photosmart C6180 for exibido no painel dianteiro, faça o resete da
seguinte forma:
1- aperte a tecla com sinal # (jogo da velha) e o número 9. Segure as 2 (# + 9) apertadas ao mesmo tempo.
2- desplugue a impressora da energia,
3- ligue (com as teclas ainda apertadas) e espere uns 15 segundos até a impressora desligar.
4- Aí é tudo normal, liga novamente ela pede as configurações iniciais, configuração da linguagem, faz a limpeza e OK!
A tinta preta original da impressora C6180 é pigmentada e as demais
corantes. Contudo para o bulk-ink é melhor utilizar só tintas corantes
que possuem melhor fluidez, evitando entupimentos e problemas. RESOLVI
O PROBLEMA DO MEU BULK-INK SUBSTITUINDO A TINTA PIGMENTADA - QUE VEIO
COM O BULK - POR TINTA TIPO CORANTE.
Your manual is available here.
Oops forgot the link!
Let me research that error some more.
OK, what you need to do is manually reset your printer:
Hold down the OK, Cancel, Black, and Color
buttons all at the same time and turn the printer off. Keep holding the
buttons down until the printer shuts off completely, then turn the printer back on. You
will have to turn the printer off twice and then it will recalibrate.
Make sure you have ink cartridges in the printer so that it can reset.
Good Luck!
Sorry, it looks like the C6180 might not have a "color" or "black" button like other HP all-in-one printers. In that case, just hold the "OK" and "Cancel" buttons in the above instructions.
Turn the printer on and wait for it to settle down and display the error. Hold down the "OK" , "Cancel"
, "Black," and "Color" buttons all at the same time and turn the printer off. Keep holding the
Yes, this problem is inherent to HP All-In-One printers across several product lines.
Here's some other users with the same problem.
Here's a lot more.
The reset key sequence I posted here is the only solution that seems to solve this error with any sort of regularity. HP does not acknowledge this problem as being user-serviceable, as you can see by all of these other frustrated users who were told the same thing as you: "Send your unit in for repair."
not working. As soon as I press the on button the error is on.
Yes I will like to obtain more assistance. On power up the printergo through a setup routine when I first got the printer. Now I observed it is giving more clicks than before and the error message on immediately. I spoke with HP but they are not helping they said it is a hardware issue but would not say specifics. The error code is indicated.
does not work
cartridges installed properly
there must a way to repair it.
i can try this out.
not working
does not work
dod not work
it is practically new
it does not reset
I could have done so without paying for fixya comments. I thought that you may have gone through this type of issue and would be able to help. Are these hardware problems inherited with HP printers that you know of?
on the c6180 there are seaparate black and color buttons for the copy and scan sections. You are saying to press all these at the same time. I have tried all these combinations, not working. Is it in the pump section that is bad? I have the 4 sides of the printer case apart. I can see the 6 tubes going from pump to printer head. I beleive this is really a bad design for the ink to travel in these tubes. Does the pump have to be primed like a water pump?
Power goes out and will not come back on.
Tried different buttons and no go
C6180
Power cord light is on but no go
help
