Www.dvddemystifiziert.de/codefree_en/sansui.html
http://www.dvddemystifiziert.de/codefree_en/sansui.html
Sansui CDVD1900 / CDVD9000 / DVD 512 / DVD 939 / DVD 967 / DVX 2000K / DVX 2900 / DVX 3050PH / RZ-7100 / RZ8700AV / VRDVD4000 / VRDVD4001 / VRDVD4005 / VRDVD5000no known hacks
SOURCE: Won't play DVDs or CDs at all. Reads error code C-104.
Sansui VRDVD4005 will record DVDs provided they are DVD-R NOT DVD+R. I have one of these for 3 going on 4 years and I took it apart and cleaned the dust off the magnetic hub and that worked for awhile but (2-3 months) now I'm having trouble finalizing again. Someone on this site said it needs 8x NOT 16x disks ... 'cause it's an older unit ... I'm checking it out in the users manuel.
magicbbs
SOURCE: SANSUI WAY TO RECORD FROM VCR TO DVD
Your model is a DVD player only and has no recording capability.
There are devices that will allow you to transfer your VHS tapes to a computer equipped with a CD/DVD writer to preserve them on disk.
Tevion is one make that comes to mind.
SOURCE: I have a Sansui model VRDVD4005. When I put a DVD
I think you need to take it to the service center, because there's nothing that you can do all by your self.The problems starts from the optical lens/ laser pick up, replacing the lens could be necessary.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
4)This
folder is the DVD/CD-ROM Drive Class Description in the registry.Look
for any of the following names in the right hand column.
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8)
Open My Computer and check to see if your CD or DVD drives
havereturned. You may also want to open Device Manager and verify that
theyellow exclamation and error code on the CD or DVD drive is gone.
