Samsung WF328AA Front Load Washer Logo
Anonymous Posted on Apr 11, 2010
ERROR CODE 3E
SAMSUNG WASHING MACHINE MODEL J1253 DISPLAYING ERROR CODE 3E AND STOPPING. HAVE CONTACTED SAMSUNG, THEY SUGGESTED SWITCHING IT OFF AND ON. TURNING OFF AND ON IS OF NO HELP AS SAME ERROR CODE KEEPS COMING ON.
5 Related Answers
A
Anonymous
  • Posted on Jan 16, 2008
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
Anonymous
  • Posted on Apr 17, 2008
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Anonymous
  • 1689 Answers
  • Posted on Jul 24, 2008
SOURCE: i have a samsung washing
here is a list of 3E's, if your error is 3E1-4 it may cost you since the DD motor can be around 150 bucks almost same with getting the motherboard replaced.
3E
Tacho error
Switch off the power/reconnect and try again
If error code persists a service call is advisable, switchboard (motherboard) replacement possible.
3E1
DD Motor fault
Check DD motor
Service call advisable
3E2
DD Motor fault
Check DD motor
3E3
DD Motor fault
Check DD motor
3E4
DD Motor fault
Check DD motor
good luck
Anonymous
  • 3 Answers
  • Posted on Jan 26, 2009
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Anonymous
  • 13 Answers
  • Posted on Apr 11, 2009
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
