Computers & Internet Logo
Anonymous Posted on Apr 06, 2010
I'm getting an error message that says "Platform Sensor".
  • 2 more comments
  • Anonymous Apr 06, 2010
    Thank for the answer. But i believe it is more of a hardware issue. Because the error says: Plaform Sensor Low Voltage
    The device is a Cyberguard firewall.
    The Error message i'm getting is:
    Platform Sensor- Low Voltage
  • Anonymous Apr 07, 2010
    More description of my problem.
    I use an alerting program to alert me every time the Cyrberguard firewall we use, encounters in error. Sorry the firewall's log has been recording and error message that says: Platform Sensor - Low Voltage. What i would to know is:does the battery that is on the firewall motherboard need to be replace or is there any other fix for this problem. Keep in mind that the the firewall platform is: Cyberguard Classic.
    They no longer support Cyberguards
Muzahura Frank
Level 3:
  • Master 2,071 Answers
  • Posted on Apr 07, 2010
Muzahura Frank
Master
Level 3:
Answers
2071
Questions
Helped
452328
Points
5838
You didn't indicate the error message being alerted by the platform sensor. but most probably, it should be an alert notification when the UPS battery is low. you if it indicates charging line is ok, then you may have to buy a new battery.
Regards
Bhautesh Patel
Level 3:
Guru:
  • Master 402 Answers
Bhautesh Patel
Master
Level 3:
Guru:
Answers
402
Questions
0
Helped
127451
Points
1181
Probably the monitor-chip on the board is working inproperly.
Consult the vendor or manufacuturer.
But before this, you may download new monitor driver from the manufacturer.
Have a great day,
Thanks.
Anonymous
Level 2:
  • Expert 242 Answers
Anonymous
Expert
Level 2:
Answers
242
Questions
0
Helped
62609
Points
726
The information that you provided is very less. However the issue is with a particular program that you are using on your computer.
If you are facing such error while opening/ running any particular program then you just have to exclude that particular program in your Firewall settings.
When you go to Firewall setting, you will get option to exclude some websites, programs and such things just give proper path where the program is installed and you will not face such error again in future.
Thanks
Jimmy
  • Anonymous May 13, 2010
    why don't you try changing the batteries on them.
Anonymous
Level 3:
  • Master 1,049 Answers
  • Posted on Apr 06, 2010
Anonymous
Master
Level 3:
Answers
1049
Questions
Helped
291471
Points
2705
This means that it is detecting the Operating system of the queried host wrong and I would simply ignore the error or turn detection off entirely. While it determines the operating system of the queried host by looking in detail at the network characteristics of the HTTP reply received from the web site. The reported operating system may be different to the one you expected because of any number of reasons that make it unreliable. For example:
  • The site could be using a web proxy cache, such as Novell BorderManager FastCache, Inktomi Traffic Server or a server running the open source Squid software. In this situation we will be connecting to the reverse web proxy rather than the originating web server, so will detect the cache's O/S rather than the web server's. Some proxy caching systems add headers to web server responses, such as the standard "Via" header. If the "Via" or "X-Cache" headers are found we report that the site is proxied.
  • The site could have a server load balancing device (SLB) like Cisco Web NS, Resonate Central Dispatch or BIG/ip. Some of these SLBs handle the TCP connection themselves, so we detect the SLB's operating system. Others use TCP/IP packet level Network Address Translation techniques, where we detect the operating system of one of the back-end web servers.
  • The site could be using a TCP connection-level proxy firewall, such as provided in the TIS Gauntlet, BorderWare, Raptor, CyberGuard or IBM SecureWay firewalls, or some other kind of HTTP level proxy. In these cases we will receive data from the intermediate machine rather than the web server, so detect the intermediate machine's operating system.
  • They could load shares across multiple servers using different operating systems with round robin DNS. In such cases each query might detect a different operating system.
  • They could have just changed the default configuration of their TCP/IP stack, perhaps for performance reasons, or have an unusual LAN environment.
  • Or something new has just come out and you have an older firmware revision that doesn't recognize newer packet standards.
Top Cyberguard Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Anonymous
Are you a Cyberguard Computer and Internet Expert? Answer questions, earn points and help others
