AL03 indicates a time out on drain fault. Either there is a restriction or blockage on the drain side of the appliance or on the pressure side.If the machine empties ok you need to locate the pressure switch, remove the thin tube and blow back into the sump to try and clear the restriction. If the machine isn't emptying or empties slowly you need to clear the restriction/blockage in the drain hose, pump or sump.
